Author Topic: dust.exe ????  (Read 1073 times)
Offline spooner
dust.exe ????
« on: May 12, 2004, 18:59 »
hi guys
everytime i boot my pc up i get a message sayin windows cannot find dust.exe ??.
has anybody had this problem or know owt about it.
let me know
cheers
spooner
sed all my sick, t`morra i`m ringing in dead !
Re:dust.exe ????
« Reply #1 on: May 12, 2004, 19:12 »
I think you have a virus known as Duster which has arrived courtesy of Kazza.
http://securityresponse.symantec.com/avcenter/venc/data/w32.hllw.studd.html
Offline spooner
Re:dust.exe ????
« Reply #2 on: May 12, 2004, 19:23 »
will do it now m8, cheers
Re:dust.exe ????
« Reply #3 on: May 12, 2004, 19:29 »
Youre on the ball tonight Clive  :o
I have been checking up on that for the last 20 minutes and came back to post it and youve beaten me to it by miles  ;)
NB. Spooner, after deleting the virus do the registery editing thing mentioned at the bottom of Clives link or it appears it slows your internet down even after the virus has been removed  :)
Offline spooner
Re:dust.exe ????
« Reply #4 on: May 12, 2004, 20:27 »
it doesn`t say anything about xp at the bottom
Re:dust.exe ????
« Reply #5 on: May 12, 2004, 20:50 »
start->run->sysedit
Modify the system.ini file as per the 98 / Me instructions (find the shell = explorer.exe command and make sure there is nothing after the explorer.exe)
