July 08, 2024, 03:32
Technical Help & Discussion
Broadband, Networking, PC Security, Internet & ISPs
URGENT HELP NEEDED !!!!
Topic: URGENT HELP NEEDED !!!! (Read 726 times)
white fly
Regular Member
May 13, 2004, 16:22 »
help me pleeeease !!!!!
this XXX thing keeps coming up , and i dont know wot to do
pleeeeeeeeease help me !!! and we're on freeserve it also says summat like xxx server , instead of freeserve , PLEEEEEEASE HELP ME quick
thanks
Re:URGENT HELP NEEDED !!!!
May 13, 2004, 16:25 »
It looks as if you have been hijacked Matt and may well be connecting at a premium rate. You need to download AdAware, get the updates and run it. Delete all the spyware it finds and hopefully you will be back to normal.
See this thread for useful url's
http://pc-pals.com/index.php?board=27;action=display;threadid=11962
May 13, 2004, 17:54 »
It's sometimes necessary to run Ad Aware in Safe Mode, if it doesn't get everything first time. I would also recommend using Spybot as well, as it sometimes finds different things to Ad Aware. The combination of the two is your best bet, followed by installing Spyware Blaster, to keep your system clean in future.
Ad Aware
Spybot S&D
Spyware Blaster
white fly
Regular Member
May 20, 2004, 10:24 »
i ran ad aware and it dint do owt , so adam ran trojan hunter and it came up with a few possible trojan files , so we went into system 32 and we found "mega porn pass" (nothing to do with me) it still has some hidden files wot should i do
Sandra
Ultimate Member
May 20, 2004, 13:53 »
Try running Hijack This Matt from here :
http://tomcoyote.com/hjt/
Paste a copy of the log file here and someone will help you by telling you which files to delete
