Author Topic: Problem installing Win 98SE  (Read 3345 times)
« on: January 07, 2003, 22:18 »
Hi Guys ,I am having a problem installing win 98se for some reason,I have done a zero fill and used Fdisk to partition and format it. Starts to install but as soon as it does it says this : boot sector write !! virus: continue y/n?
 It wont accept Y or N and my only option is to close down again.I have just tried a different win 98se disc and get the same message.
Any ideas greatly appreciated  ???
Re:Problem installing Win 98SE
« Reply #1 on: January 07, 2003, 22:22 »
Thats easy Sandra!
Just disable the antivirus protection in your BIOS and start the installation again.
« Reply #2 on: January 07, 2003, 22:49 »
Sorted now Adept,thanks for the quick response.I thought of that when my friend told me about the message before he brought it over but I am not used to Amibios setup and had looked twice for it before I started without seeing it  ::)
I will now go and stand in the corner and hang my head in shame and wait for Rodders to administer the 30 lashes  :(
« Reply #3 on: January 07, 2003, 22:50 »
You wish  ::)
« Reply #4 on: January 07, 2003, 23:06 »
Sandra!  I'm shocked!  You have me figured all wrong -- I usually work in multiples of six.  8)
« Reply #5 on: January 07, 2003, 23:32 »
According to my maths Rodders 30 is 5 multiples of 6,or did you mean your women that you doin multiples of 6  ::)
« Reply #6 on: January 07, 2003, 23:42 »
Congratulations, Sandra!  You have successfully negotiated Stage 1 of our blondness test.  Please press the big button on the front of your PC to proceed to the next phase.   ;D
« Reply #7 on: January 07, 2003, 23:50 »
I am not a blonde  ::) I am a free woman ( Misquoted from The Prisoner ) and of reasonable to fair intelligence ,or so I have been told  ;)
« Reply #8 on: January 07, 2003, 23:58 »
I'll go along with that.   :-*
Offline bat69
« Reply #9 on: January 08, 2003, 10:02 »
Just wait until Serenity sees this ... you'll have to hide Rodders  ;) ;)
Offline Serenity
« Reply #10 on: January 08, 2003, 11:21 »
Ahhh but testimony from the family Cat dont hold much Creedance round here!!  :P  ;D
p.s. Rodders ..I will deal with you later!  >:D
« Reply #11 on: January 08, 2003, 19:29 »
What, when your medication wears off?  Come off it Serenity, you'll have forgotton by then!
