Author Topic: Email/File server  (Read 2087 times)
Offline dingo
Email/File server
« on: May 17, 2004, 04:30 »
Hi guys,
Could anyone please tell me what is the disadvantage of using a single server for both file and email service?
What are the reasons for using separate servers for this?
Thanks in advance.
Re:Email/File server
« Reply #1 on: May 17, 2004, 07:15 »
Hi Dingo :welcome:
I think it is down to the amount of people who will be accessing these functions.
If you are an organisation of hundreds of people, all regulrarly accessing files and emailling, a single server may not be able to adequately supply enough power for both functions.
Another advantage of separate servers is that they can be restarted independantly.
I look after a number of servers in my organisation of sixty or so people. Our main server is a twin 2.8GHz Xeon with 2GB of memory. It is more than adequate to serve the demands of the Exchange server software and file & print sharing for this number of people.
« Reply #2 on: May 18, 2004, 07:33 »
someones always gotta outdo ya i guess.... mines just a amd 2.1gig with 1gig of memory ::)
Offline dingo
« Reply #3 on: May 18, 2004, 11:28 »
Thanks Adept.
Just a thought, would the fact that all the companies data resides on the same computer as their incoming email cause problems (i.e a virus attached to an email)?
« Reply #4 on: May 19, 2004, 07:01 »
Potentially, yes. But if you have adequate anti-virus protection this shouldn't be a problem. We have two separate anti-virus applications, one to check the incoming mail and another to check the files. Anti-virus software is also deployed to the workstations as a final protection measure.
