Author Topic: bt broadband  (Read 1209 times)
Offline princeofdarkness
bt broadband
« on: May 18, 2004, 17:11 »
hi
i am getting the 512k bt broadband for 29.99 0r summat but i need my mums pc which is downstairs,my pc which is upstairs and my xbox which is upstairs all to be connected via ethernet cable and i dont want to network mine and my mums pc or have to keep swapping cables.. what will i do about it? how will i do it? and how much will it cost me?
p.s obviously i must be able to use the phone as well  ::)
thanx in advance Jonah
quot;Spirits damned to rot
Eyes of the dead
Broken glass reflections
Show your flesh eaten away
Offline DJ
Re:bt broadband
« Reply #1 on: May 18, 2004, 17:15 »
You would be best with a Broadband router and modem in one (unless BT are going to give you a modem with the package).  Then you just need to run the cables to your PC, the XBOX and the other PC.
Another option is to go wireless - so you don't need to run cables all over the place - but an added expense of buying PCI cards for the other PC would be incurred (not sure about Wireless and XBox).
Have a look at http://www.broadbandbuyer.co.uk (Not the cheapest site, but good for ideas).
Good Luck!
DJ
Re:bt broadband
« Reply #2 on: May 18, 2004, 22:26 »
Using a router you can create a network to share your pcs and Xbox for the internet connections then just disable the file sharing part between pcs  :)
Re:bt broadband
« Reply #3 on: May 19, 2004, 01:04 »
£30 for broadband....your wrong in your head  :-X
Offline DJ
Re:bt broadband
« Reply #4 on: May 19, 2004, 09:58 »
Not sure if I've got the wrong end of the Stick here, but the £29.99 that **Jon@h** refers to will be the monthly cost of BT brodband (I think).
DJ
Offline Camstop
Re:bt broadband
« Reply #5 on: May 19, 2004, 14:35 »
I think the likes of this was Tonys point...>> ;)
Offline DJ
Re:bt broadband
« Reply #6 on: May 19, 2004, 14:40 »
Ah  ;D good point Tony.
I use Force9 (due to the amount of webspace) and get it for £21.99 with no restirctions / contract etc.
There are better deals than BT out there  ;)
DJ
Re:bt broadband
« Reply #7 on: May 19, 2004, 14:59 »
Yes Force 9 /Plusnet do come with good webspace 250MB methinks, of the top of my head. And like you say £21.99 [non restricted] is better than paying £29.99 for BT's offering.
And if your prepared to take a resticted service [in that you have a monthly download limit] but still have 512KB always on broadband, you can get it for £14.99 from Plusnet.
