Author Topic: Hard drive partioning  (Read 920 times)
Offline JK
« on: May 19, 2004, 13:18 »
Hi
Need some advice about partioning a new 80G hard drive.
I use Windows ME with FAT32. Should I have it as one
partion, or two? I have seen comments in a PC magazine
saying that large partions cause problems if you use FAT32.
Re:Hard drive partioning
« Reply #1 on: May 19, 2004, 14:10 »
I havent heard of a problem with 80 gig as FAT 32  ???
The advantage of partitioning the drive is that if you get a problem with your OS then you can just format the partition that it is on and reinstall to that partition, without losing any saved data on the second partition.
Therefore I would partition it for that reason rather than anything to do with the size of the drive and FAT 32  :)
« Reply #2 on: May 19, 2004, 14:28 »
I'll second Our Sandra  :)
Offline JK
« Reply #3 on: May 21, 2004, 20:48 »
Hi Sandra
Thank you for your reply.
I have heard that you should not have a FAT32 partition larger
that 64G, as file utilities such as ScanDisk hit internal limits.
Offline JK
« Reply #4 on: May 29, 2004, 22:50 »
Hi Sandra
I have checked and found out that there is a FAT32 limit it's 64G.Although you can have a bigger size it will cause problems, scan disk and other tools with lockup. I have now made my new 80G drive into two partions.
« Reply #5 on: May 30, 2004, 01:31 »
Thanks for that JK, I hadnt come across that before but as I said its always beter to have your OS on a seperate partition anyway  :)
Offline JK
« Reply #6 on: May 30, 2004, 21:58 »
Thank you very much Sandra.
Found out about the 64G limit in a computer mag. You can have
a larger partion, but it will cause problems and lockup's with
windows disk utilites.
Offline ketamininja
« Reply #7 on: June 01, 2004, 19:28 »
^ but no one uses the Windows tools??? :p
My advise would be to upgrade to XP Home if your PC can handle it.
