April 07, 2025, 17:58
Technical Help & Discussion
links do not appear
Topic: links do not appear (Read 803 times)
Terry
New Member
links do not appear
May 21, 2004, 08:17 »
When I press on a Web link within a page a white screen appears. Clicking on refresh does not help.Any suggstions?
erry
Re:links do not appear
May 21, 2004, 08:30 »
It may just be that the webpage you are looking for is temporarily unavailable. Best to try again at a later date.
May 21, 2004, 09:37 »
Is it just one link on one site, Terry, or is this happening with all links? If it's just one link on one site, then Clive is probably correct, in that either the linked page is down, or has been removed.
joudi
Established Member
May 21, 2004, 09:46 »
When did that start to happen?
Did you remove any file or program before it happened?
Do you have too high level fire-wall?
You may try to pass "Ad-aware" and "spybot" or "Hijack this" or even your antivirus after updating them. For it might be a trojan too.
If not, maybe "IE" will be worthy to repare.
Terry
New Member
May 22, 2004, 16:24 »
many thanx
I had discarded my WIn98 SE cos of a MSN bug and rthe "old" version lacked about 60 Updates! will file all the advice for next time!
erry
links do not appear
