November 28, 2024, 01:48
Technical Help & Discussion
Broadband, Networking, PC Security, Internet & ISPs
HJT Log: Should I remove this?
Topic: HJT Log: Should I remove this? (Read 807 times)
May 23, 2004, 19:03 »
Found this with Hijack This - should I fix it? Looks iffy to me.
O17 - HKLM\System\CCS\Services\Tcpip\..\{A25D365E-A502-4B5D-B3D3-F0FE15E5B553}: NameServer = 62.241.160.200 158.43.240.3
Dack
Established Member
Re:HJT Log: Should I remove this?
May 23, 2004, 19:12 »
Sounds a bit odd as one of the nameservers points to Pipex while the other is on Network solutions. Maybe how Pipex works though.
If you delete it then it will re-appear - it's the TCP connection details for your DNS servers.
May 23, 2004, 20:36 »
Oh right, thanks Dack. It was just that in the info it said that 017 is a Domain Hijack.
Dack
Established Member
May 23, 2004, 20:45 »
It basically just means you were connected to the internet when you ran HJT
May 23, 2004, 20:53 »
OK
