Author Topic: Building My First!  (Read 1646 times)
Offline Stormy
    • http://plainfolkauctions.com
Building My First!
« on: May 24, 2004, 14:02 »
Building my first new pooter.  Am I missing anything or should I change anything?  Wanna get your opinions before I start buying the parts.  I do web developement and need a good system for that.  :)
ATI Radeon 9800 Pro Video Card / 128MB DDR / AGP 8X / TV Out & DVI
Asus - A7N8XE-Deluxe - nVIDIA nForce2 Socket A ATX Motherboard with Audio, AGP 8X, USB 2.0, FireWire, WiFi, Serial ATA, RAID and Dual Gigabit Ethernet LAN Support
Intel® Pentium® 4 2.4Ghz / 512k Cache / 800Mhz FSB / Socket 478 / HyperThreading / Processor
AOC LM720NB 17" 1280x1024 Black LCD Monitor
Powmax Black & Silver ATX Mid-Tower Case with Handle, Clear Side, Fan and 400Watt Power Supply
16x DVD-ROM Drive / PowerDVD Software / OEM
Sony CD Burner / 52x24x52x CD-RW / Nero Software / White Box
1.44MB Floppy Disk Drive (Black)
Premium 256MB PC2100 DDR 266MHz Memory
Premium 512MB PC2100 DDR 266MHz Memory
amp;quot;Be wise in the use of time. The question in life is not how much time do we have? The question is what shall we do with it.
-Anna Robertson Brown-".
Re:Building My First!
« Reply #1 on: May 24, 2004, 14:49 »
Unfortunately Stormy that mobo is for an AMD cpu not an Intel one so you would have to use an AMD cpu.
AMD's Athlon XP 3200+ and all follow-up CPUs now support 400MHz FSB for increased office productivity and enhanced digital media experience,(The Asus sites words not mine  ;) )
As that mobo has a 400 FSB then you are losing performance by using 266 pc 2100 DDR, you should be thinking of DDR400-PC3200.
Unless you specifically want an Intel cpu you would probabbly find that the difference in price between the latest/fastest AMD and Intel cpus would pay for the difference in the 266 and the 400 DDR ram  :)
Offline Stormy
« Reply #2 on: May 24, 2004, 17:22 »
Should I change the Mobo or the cpu?
« Reply #3 on: May 24, 2004, 17:47 »
You tend to get more 'bang for your bucks' with AMD CPUs, i.e., an AMD CPU would usually be cheaper than it's equivalent Intel.
« Reply #4 on: May 24, 2004, 19:09 »
I'd just add that it's probably worth you getting a DVD-Writer instead of the seperate units as:
a. it works out about the same price £60 or so.
b. You'll get a better capability i.e. you'll be able to write dvd's
NEC2500 is probably the best about now (especially as a hacked dual layer firmware was recently released :))
Graphics card is pretty good and can be bought for about £130 from http://www.lowestonweb.com/Products/DisplayInfoMain.asp?e=2F99A0AD-B9A8-470B-B643-2A672531F699
A very good motherboard is the DFI one on sale in PCWorld (honest!) for £48 - its this one http://www.dfi.com.tw/Product/xx_product_spec_details_r_us.jsp?PRODUCT_ID=2141
Barton core Athlon 2500 is about £55 from ebuyer - remember to buy a fan and heatsink though if you get the OEM version.
As Sandra said, get the best memory you can - definately PC3200.
Offline Stormy
« Reply #5 on: May 25, 2004, 01:17 »
I was gonna get a dual dvd unit but then I thought about it that if one broke down I'd still be able to use the other so I went with the two instead.  On the NFII ULTRA INFINITY mobo, what wattage is it?  I'm wanting to have a 400 watt but I can't find any info on that with this board.
« Reply #6 on: May 25, 2004, 01:37 »
Specifications and a revue on that mobo here Stormy :
http://www.mbreview.com/nf2inf.php
A 400 watt PSU should be fine  :)
Offline Stormy
« Reply #7 on: May 25, 2004, 03:38 »
That works Sandra!  ;D
« Reply #8 on: May 29, 2004, 19:06 »
By anyone we know ? :P ;D
