Author Topic: boot up problem in win 2000  (Read 1178 times)
Offline spooner
« on: May 29, 2004, 14:31 »
just tried to start my other pc, but on the start up screen it says invalid system disc, replace the disc and press any key ??, never done this before, when i press a key it says boot failure insert boot discette in A: ??
help please
cheers
sed all my sick, t`morra i`m ringing in dead !
Re:boot up problem in win 2000
« Reply #1 on: May 29, 2004, 14:49 »
Its got a problem in the boot record of your hard drive, thats where the system files are stored and it cant find them.
Unless somehow you have set the bios to boot from floppy only, but I think you would have known if you had done that of course.
Will it start in Safe Mode ?
Which OS are you using ?
Offline spooner
« Reply #2 on: May 29, 2004, 17:20 »
hi sandra, how do i start in safe mode, i`m using win 2000
« Reply #3 on: May 29, 2004, 19:09 »
Repeatedly hit the F8 key after the post beep  :)
« Reply #4 on: May 30, 2004, 12:35 »
Just a thought, but you haven't left a disc in one of your drives, have you?
Offline spooner
« Reply #5 on: May 30, 2004, 12:47 »
i had a floppy in the first time i tried to boot up, then i switched off took out floppy but since then it`s not been right  ???. i can start in safe mode, what should i go into to check the correct settings ?
« Reply #6 on: May 30, 2004, 12:55 »
Sounds like you might have to go into BIOS (hit DEL at the prompt during boot up), and look at Boot Settings / Boot Sequence, or similar, and make sure it's set to boot from the Hard Drive.  I don't know how, but it looks like it's been set to boot from the Floppy Disc 'A:' drive.
Offline spooner
« Reply #7 on: May 30, 2004, 13:32 »
started then shut down in safe mode, rebooted and it`s fine,  weired  ???, thanks for your help  ;)
