Author Topic: check disk log file??  (Read 766 times)
Offline jon996
« on: May 29, 2004, 17:29 »
hi all...
i did a check disk and there were sum bad sectors and i wanna no what they were. i know that there were cos i lookd at it and there were sum then i left it and then it then i lookd again and it had restarted so i was wondering weather there was sum sort of log file wher i can see the things tht were bad sectors
>>if this makes any sence at all!!!!!!
cheers
jonnnnnnnnnnnnn
rive it like you stole it!
Re:check disk log file??
« Reply #1 on: May 29, 2004, 19:41 »
Do you mean chkdsk or scandisk Jon? AFAIK chkdsk doesn't create a log. The 98 / me version of scandisk creates a file called scandisk.log (use start|find to find it) and the 2000/xp version either writes to the event log or creates a scandisk.log somewhere ???
edited die to a problem with [slash]me ::)
