Author Topic: Two things  (Read 1082 times)
Offline madmatt911
    • http://e-humor.net
Two things
« on: June 02, 2004, 23:42 »
first. how can i access my hotmail and aol accounts from outlook express?
second. is it possible to "clone" my sisters copy of windows me (OS system files) onto a cd so i can use it on my pc? if so how do i go about doing that?
URL=http://e-humor.net][/URL]
Get Firefox!
Re:Two things
« Reply #1 on: June 02, 2004, 23:51 »
First: Yes, just go to Tools > Accounts, click New, and put in your details.  If you put a Hotmail address in, it will come up as a Hotmail HTTP account at the next part of the set up.  Not sure if it will work with AOL though.  :-\
Second: Unfortunately, what you are asking amounts to pirating a version of Windows, and we can't discuss that here.  Sorry.   :)
Offline greenking
Re:Two things
« Reply #2 on: June 03, 2004, 00:52 »
But theoretically it is possible  :-X
Offline madmatt911
Re:Two things
« Reply #3 on: June 03, 2004, 00:56 »
i would if it wasnt pirating. thanks/anyway
Get Firefox!
Re:Two things
« Reply #4 on: June 03, 2004, 09:06 »
I don't think you can just transfer an operating system from one machine to another.  You would need an installation disc and a product key (licence).  If you have the CD, there may be places on the Internet where you could obtain a product key.  That's all we can really say.   ;) :-X
Offline ketamininja
Re:Two things
« Reply #5 on: June 04, 2004, 18:18 »
If your PC died, and you had to get a new one, then you could technically use the same Windows product and key, because it wont be being used on the other PC ;)
The same applies to MOST programs, but Windows especially: you MUST install from the CD, it cannot be cloned.
Other programs MUST be installed to work properly, and not just copied across (this applies to at least 80% of programs). The install will not only put the files/folders in the directories, but also add many lines to the Windows Registry (database) and may have to interact with hardware.... INSTALLS ARE IMPORTANT!
