Also could you explain how to install drivers after you have downloaded them, and how to remove old ones if you have to do that. Is there a way of checking which drivers are installed.
Many thanks. - Sorry if this is too many questions but what is the difference between USB 1.1 and USB 2.0 ??
Which OS are you using PWS ?
If its XP you can go into the device manager and click on the hardware that you are interested in, click on properties and then look for the driver information.
You can remove or update drivers from in there too.
To install new drivers you can click on update driver and then browse to the location where you have the new drivers saved and click next and follow the instructions.
USB 1, 1.1 and 2 are the oldest to the newest type of USB.
USB 1 is Low Speed 1.5M bit/sec
USB 1.1 is Full Speed 12M bit/sec
USB 2 is High Speed 480M bit/sec
As you can see the jump from USB 1.1 to USB 2 is a big increase in the transfer speed of data
