Author Topic: Cover artwork  (Read 1323 times)
Cover artwork
« on: June 07, 2004, 00:14 »
If you have ever mislaid the cover of one of your DVD's, this site maintains a huge archive of cover graphics from which one can easily recreate a temporary facsimile for use until the original turns up from beneath the sofa.
Film buffs may also find it particularly useful for reference purposes.
Re:Cover artwork
« Reply #1 on: June 07, 2004, 11:50 »
http://daprogger.mine.nu/
Also contains rather good quality covers too - much higher resolution ones than the other site and without popups.
:whistle:
Re:Cover artwork
« Reply #2 on: June 07, 2004, 12:44 »
Be careful as this program is full of spyware, please make sure you have some kind of spyware turned on?
Re:Cover artwork
« Reply #3 on: June 07, 2004, 14:38 »
YAY!!!!! Hook is back!!   :hatoff: :hatoff:
