Author Topic: Should I block this?  (Read 1371 times)
« on: June 07, 2004, 15:47 »
Each time I go to disconnect from the Internet, Sygate  is popping up with the box below.  I have just done Ad Aware and Spybot scans, and have Spyware Blaster, and Trojan Hunter running.  It seems that Windows Explorer is trying to tell something that I am signing off.  Should I block or allow this?   :-\
Re:Should I block this?
« Reply #1 on: June 07, 2004, 18:52 »
Its a bug in Norton I believe  ;)
« Reply #2 on: June 07, 2004, 21:54 »
I'm not using Norton, Hook.  It's Sygate.  :)
Any ideas, anyone?  It still keeps asking!   :-\
« Reply #3 on: June 07, 2004, 23:00 »
Well Simon, if saying no does not effect any running systems, tick the "remember answer" say no, and get on with the rest of your life mate ;D ;)
« Reply #4 on: June 07, 2004, 23:01 »
Have you tried running Shields Up to see if port 80 is stealthed Simon?
« Reply #5 on: June 07, 2004, 23:28 »
Yes, Clive, all stealthed.
« Reply #6 on: June 08, 2004, 07:10 »
crl.verisign.com seems to be some kind of certificate repository.
I would guess that something on your PC is requesting verification of a digital certificate for some reason. Seems odd for it to happen through explorer.exe though.
I would block it until you find out whether it is useful, or something breaks ;)
« Reply #7 on: June 08, 2004, 07:51 »
Well, the information I found here suggests it's checking for updates to Digital Certificates, so, on balance, I've allowed it.  If I block it, there's a 5-6 second lag each time I right click something in Windows Explorer, like the poster in that thread.
« Reply #8 on: June 08, 2004, 12:48 »
I block everything i'm not sure about simon, so personally i'd go with tonys suggestion.   ;)
