hi sandra I have tried to install the driver for the modem here are the instrustions tha i was given
ok when you go into ms dos... type A:
to get into your floppy drive -
from there, type dir/p (to get a list of files on a
drive)
You will see a file called 'Install.exe'
Type install and it will bring you onto set up screen
where you will be able to install the driver
after that should the modem start automatically or do i have to select what irq address it is to use
whats the next step
