Author Topic: AUTOCOMPLETE  (Read 869 times)
Offline gudda96
AUTOCOMPLETE
« on: June 25, 2004, 13:48 »
I AM TRYING TO MAKE SURE I CAN AUTOCOMPLETE FORMS ON WEB AS I USED TO BUT NO LUCK.
I HAVE TRIED IE/OPTIONS/ADVANCED/TICK INLINE AUTOCOMPLETE TO NO AVAIL.
ANY TIPS PLEASE.
P/ZA/MW/SB/AW/Avast/OE/
Re:AUTOCOMPLETE
« Reply #1 on: June 25, 2004, 14:08 »
I think it's Tools » Internet options » Content » AutoComplete you should be looking for.
if you want to try a free, secure form filler, you might want to have a look at Roboform.   :)
Re:AUTOCOMPLETE
« Reply #2 on: June 26, 2004, 11:31 »
ANY TIPS PLEASE.
You could try not SHOUTING ;D ;D :P :heehee:
Offline ketamininja
Re:AUTOCOMPLETE
« Reply #3 on: June 26, 2004, 15:13 »
Autocomplete will of course not work until you have switched ON that seeting, and then typed in stuff for it to remember.
After that (I think you might have to enter the details twice - i mean go to the website and log in twice to remember) it should all be working?!
