Author Topic: monitor.exe  (Read 1765 times)
monitor.exe
« on: June 25, 2004, 21:06 »
more virus shenanigans.  i got the BLOODHOUND.EXPLOIT.10 virus which norton intercepted.  i also ran spybot which removed amongst other things 2 copies of "prolivation" prefix changes in the registry which i havent seen before. my homepage had also been changed to some sort of product search engine. (which i've changed back to my normal homepage)
now when i boot i get 2 messages about not being able to find monitor.exe.  i checked the entry in STARTUP and found it listed under EXPLORER.  i removed this from the startup programs but still get the message about explorer.exe when i boot up, and i'm also told that the system configuration utility is in diagnostic or selective startup mode, choose normal mode to start windows normally & undo changes made using system configuration utility.
If i do this i'm back to the monitor.exe messages.  grrrrr
any ideas as its annoying me.  the pc seems fine otherwise
Re:monitor.exe
« Reply #1 on: June 25, 2004, 22:17 »
It may be set to run from the registry, Dave.  Suggest you run Hijack This, which you should be able to 'fix' it with.   :)
Re:monitor.exe
« Reply #2 on: June 26, 2004, 00:19 »
Thanks simon i'll try that.  its more of an annoyance than a big problem and digging deeper it seems other people appear to have had the same problem.  ;)
Re:monitor.exe
« Reply #3 on: June 26, 2004, 00:38 »
This is what i got....it seems to think the entries f0 and f2 which refer to monitor.exe have been altered.  question is what do i do if anything ?????    p.s.   i notice that all the "r" entries bar my home page refer to the site i was redirected to.
Logfile of HijackThis v1.97.7
Scan saved at 00:23:58, on 26/06/2004
Platform: Windows XP SP1 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
C:\WINDOWS\Explorer.exe
C:\Program Files\Common Files\Symantec Shared\ccApp.exe
C:\Program Files\Creative\SBLive2k\Launcher\CTLauncher.exe
C:\Program Files\Creative\SBLive2k\AudioHQ\AHQTB.EXE
C:\PROGRA~1\ZONELA~1\ZONEAL~1\zlclient.exe
C:\WINDOWS\System32\ctfmon.exe
C:\Program Files\Messenger\msmsgs.exe
C:\Program Files\SETI@home\SETI@home.exe
C:\WINDOWS\System32\devldr32.exe
C:\WINDOWS\System32\CTSvcCDA.exe
C:\Program Files\Common Files\EPSON\EBAPI\SAgent2.exe
C:\Program Files\Norton AntiVirus\navapsvc.exe
C:\Program Files\Norton AntiVirus\AdvTools\NPROTECT.EXE
C:\WINDOWS\system32\srvany.exe
C:\WINDOWS\system32\resetservice.exe
C:\WINDOWS\system32\ZoneLabs\vsmon.exe
C:\Program Files\Creative\SBLive2k\Launcher\TaskGuide\updtray.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\Documents and Settings\Davee\Desktop\HijackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://195.225.176.14/
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.btopenworld.com/default
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://195.225.176.14/
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://195.225.176.14/
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://195.225.176.14/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://195.225.176.14/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://195.225.176.14/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://195.225.176.14/
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch = http://195.225.176.14/ie
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant = http://195.225.176.14/ie
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page = http://195.225.176.14/
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = http://195.225.176.14/
F0 - system.ini: Shell=Explorer.exe monitor.exe
F2 - REG:system.ini: Shell=Explorer.exe monitor.exe
O2 - BHO: (no name) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 6.0\Reader\ActiveX\AcroIEHelper.dll
O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program Files\Norton AntiVirus\NavShExt.dll
O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton AntiVirus\NavShExt.dll
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\System32\msdxm.ocx
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [ccRegVfy] "C:\Program Files\Common Files\Symantec Shared\ccRegVfy.exe"
O4 - HKLM\..\Run: [Advanced Tools Check] C:\PROGRA~1\NORTON~1\AdvTools\ADVCHK.EXE
O4 - HKLM\..\Run: [NeroCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [UpdReg] C:\WINDOWS\Updreg.exe
O4 - HKLM\..\Run: [Creative Launcher] C:\Program Files\Creative\SBLive2k\Launcher\CTLauncher.exe
O4 - HKLM\..\Run: [AudioHQ] C:\Program Files\Creative\SBLive2k\AudioHQ\AHQTB.EXE
O4 - HKLM\..\Run: [Zone Labs Client] C:\PROGRA~1\ZONELA~1\ZONEAL~1\zlclient.exe
O4 - HKCU\..\Run: [CTFMON.EXE] C:\WINDOWS\System32\ctfmon.exe
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKCU\..\Run: [seticlient] C:\Program Files\SETI@home\SETI@home.exe -min
O4 - HKCU\..\Run: [monitor] Explorer.exe monitor.exe
O4 - Global Startup: EPSON Status Monitor 3 Environment Check 2.lnk = C:\WINDOWS\system32\spool\drivers\w32x86\3\E_SRCV02.EXE
O4 - Global Startup: Microsoft Office.lnk = C:\Program Files\Microsoft Office\Office\OSA9.EXE
O9 - Extra button: Messenger (HKLM)
O9 - Extra 'Tools' menuitem: Messenger (HKLM)
O15 - Trusted Zone: http://www.otherworldne.org.uk
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
Re:monitor.exe
« Reply #4 on: June 26, 2004, 08:54 »
Dave, Hi & Goodmorning.
There is one or two in there that looks a bit dodgy
Edit: just had a rethink  ;D
All those R1 & R0 they don't look right? I could be totaly wrong but they all say start page  :o
Hookstar
Re:monitor.exe
« Reply #5 on: June 26, 2004, 10:24 »
Whilst I'm no expert at these, I agree with Hook. :o  I think you should fix all of the following:
It's that last one which probably keeps popping up when you start the PC.  :(  Hopefully Dack will be along to have a look soon.  He's good at HJT logs.
Re:monitor.exe
« Reply #6 on: June 26, 2004, 10:33 »
thanks guys  ;) i'll hang on and see what dack has to say before i start blundering through it all.  like i say the only problem i get to my knowledge is a couple of dialogue boxes complaining windows cant find monitor.exe which i just close....more of an annoyance than anything.
the btopenworld reference is actually my real homepage which i've sucessfully restored, the rest i think is dodgy.  i believe you can do without monitor.exe but i'll wait for further advice.   :P
Re:monitor.exe
« Reply #7 on: June 26, 2004, 11:51 »
Quick reply as currently in the middle of a crisis :)
The ones you need to delete are:
Much like Simon said :)
HOWEVER
It may be a new variation of Coolwebsearch and as it's attaching itself to Explorer it is probably worth you booting up in safe mode to try and clear them out.
Re:monitor.exe
« Reply #8 on: June 26, 2004, 11:52 »
Thanks mate   ;)
Re:monitor.exe
« Reply #9 on: June 26, 2004, 12:12 »
Worked a treat many thanks guys and especially Dack for taking time out to sort it.
the 15 files i deleted ended up on the desktop as backup files so i've stuck 'em in a folder, presumably ok to delete them if all works ok.  :D ;)
Re:monitor.exe
« Reply #10 on: June 26, 2004, 13:08 »
Yep - thats what you get when you save/run things on the desktop :)
Now back to finishing the decorating/construction/cleaning up as I move all my computer equipment to the newly decorated garage :(
Expected to have it all finished by now but spent the last 3 days in and out of hospital due to the other half getting high blood pressure. Totally England match unrelated :)
Re:monitor.exe
« Reply #11 on: June 26, 2004, 13:21 »
Hope your collective blood pressures are back to normal soon  ;)
