Author Topic: Animations  (Read 1166 times)
Animations
« on: June 25, 2004, 22:27 »
I can't see any movement on animations. I can see movement on signatures but not on the smileys. I have found this is not just on here but elsewhere as well. Any suggestions how I can correct this. ???
PS Even Bart keeps his trousers up.  ;D
Re:Animations
« Reply #1 on: June 25, 2004, 23:44 »
Does that happen in IE as well as Mozilla Lona as it sounds like a Mozilla type of problem  ???
Re:Animations
« Reply #2 on: June 25, 2004, 23:50 »
It happens in both. I can see the animation at the bottom of this screen ( smillie face which changes to red lips). Could be this new firewall I have installed. I will keep checking all the different settings to see if there is something I've accidently blocked.
Re:Animations
« Reply #3 on: June 26, 2004, 00:01 »
Has this just started happening without adjusting any settings, Lona?  In Mozilla, there's an option under Edit > Preferences > Privacy & Security > Images (see below), but in IE, I think you can only show images, or not, in which case you get the box with the red x in the middle.
Re:Animations
« Reply #4 on: June 26, 2004, 00:11 »
Thanks for that Simon. :) Checked preferences and it looked the same as yours.
I can see the images, it's just that they are not animated.  :(
Re:Animations
« Reply #5 on: June 26, 2004, 00:18 »
Did it start happening immediately after installing the new firewall?  I would have thought it unlikely to affect images, but to eliminate it as the cause, how about trying a different one?  I'll probably get the p*** taken out of me, for recommending a good product (funny, I thought that's what we were here for), but this one is very useable...
Re:Animations
« Reply #6 on: June 26, 2004, 00:19 »
I think I have solved my problem. Well I hope I have. I had blocked animation in new firewall.
It's strange that I could still see all the movement in the signatures. ???
Re:Animations
« Reply #7 on: June 26, 2004, 00:30 »
The sigs are .swf files while the smilies are .gif files, thats probably why Lona  :)
