Author Topic: I Was Hit!  (Read 1592 times)
Offline Stormy
    • http://plainfolkauctions.com
I Was Hit!
« on: June 30, 2004, 01:11 »
I'm not sure what hit me but something did!  I ran adware and deleted what came up there but I think I still have the problem.  I cannot use my scan disk or defrag.  I was able to use the scan disk in safe mode but not the defrag.  When I try to run scan disk, it keeps going back and forth between "checking allocated files" and "checking folders".  Like something is running in the background but not showing up in the cntr/alt/del.  Im stumped.  I've just backed up a lot of my files as I have a bad feeling I'm gonna have to reformat my hard drive.  No matter what kind of scan I try to do, it freezes.  Any ideas before I clean house?  :-\
amp;quot;Be wise in the use of time. The question in life is not how much time do we have? The question is what shall we do with it.
-Anna Robertson Brown-".
Re:I Was Hit!
« Reply #1 on: June 30, 2004, 02:16 »
This happened to me once Stromy. I think if you do Ctrl,alt del and shut down nearly everything that's running in the backround then try again it might work. Also if you have task scheduler running that can stop your defrag so disable scheduled tasks.
Disable firewall and antivirus as well.  Hope this helps.
Re:I Was Hit!
« Reply #2 on: June 30, 2004, 08:01 »
There's a little program called End It All, which kills anything running on your system at the click of a mouse, except, of course, Explorer and Systray.  That might help, or you could try running Ad Aware and Spybot in Safe Mode, with System Restore (XP / ME) temporarily switched off.
Offline measter
Re:I Was Hit!
« Reply #3 on: June 30, 2004, 20:29 »
if it ends everything apart from explorer and systray on xp, the pc will restart. you need svchost running. :P
Current CPU Info
Re:I Was Hit!
« Reply #4 on: June 30, 2004, 20:34 »
Well, it ends everything it can end to keep the PC running.   :P
Offline Stormy
Re:I Was Hit!
« Reply #5 on: July 01, 2004, 01:18 »
I have the "end it all".  It usually leaves explorer and systray running but that's it. But strange that this time explorer is not locked like it use to be and I also noticed that some sort of program was running my modem (I use a cable connection) so I went into the control panel and turned off the modem and that canceled that one out of the end it all, but something called "kernal32.dll" is locked and I can't shut it down.  I cannot locate where to find it either like the modem one.  I've tried all the above and still cannot use my scan disk or defrag.  I guess I'll be spending a good part of Saturday reformatting my hard drive and then reinstalling my programs.  :-\
Offline Stormy
Re:I Was Hit!
« Reply #6 on: July 01, 2004, 22:34 »
Anyone see anything "suspicious" in this log?
Logfile of HijackThis v1.97.7
Scan saved at 5:32:01 PM, on 7/1/2004
Platform: Windows ME (Win9x 4.90.3000)
MSIE: Internet Explorer v6.00 SP1 (6.00.2800.1106)
Running processes:
C:\WINDOWS\SYSTEM\KERNEL32.DLL
C:\WINDOWS\SYSTEM\MSGSRV32.EXE
C:\WINDOWS\SYSTEM\mmtask.tsk
C:\WINDOWS\SYSTEM\MPREXE.EXE
C:\WINDOWS\SYSTEM\ZONELABS\VSMON.EXE
C:\WINDOWS\SYSTEM\STIMON.EXE
C:\WINDOWS\SYSTEM\MSTASK.EXE
C:\PROGRAM FILES\COMMON FILES\SYMANTEC SHARED\CCEVTMGR.EXE
C:\WINDOWS\SYSTEM\RESTORE\STMGR.EXE
C:\WINDOWS\EXPLORER.EXE
C:\WINDOWS\SYSTEM\SYSTRAY.EXE
C:\PROGRAM FILES\COMMON FILES\KODAK\HYDRA_DR\DCFSSVC.EXE
C:\PROGRAM FILES\PESTPATROL\PPMEMCHECK.EXE
C:\WINDOWS\SYSTEM\WMIEXE.EXE
C:\PROGRAM FILES\MICROSOFT HARDWARE\KEYBOARD\TYPE32.EXE
C:\WINDOWS\SYSTEM\HPOOPM07.EXE
C:\PROGRAM FILES\PESTPATROL\PPCONTROL.EXE
C:\WINDOWS\TASKMON.EXE
C:\PROGRAM FILES\PESTPATROL\COOKIEPATROL.EXE
C:\WINDOWS\SYSTEM\SPOOL32.EXE
C:\WINDOWS\SYSUPD.EXE
C:\PROGRAM FILES\COMMON FILES\SYMANTEC SHARED\CCAPP.EXE
C:\PROGRAM FILES\ZONE LABS\ZONEALARM\ZAPLUS.EXE
C:\WINDOWS\SYSTEM\DDHELP.EXE
C:\PROGRAM FILES\YAHOO!\MESSENGER\YPAGER.EXE
C:\PROGRAM FILES\OUTLOOK EXPRESS\MSIMN.EXE
C:\WINDOWS\SYSTEM\PSTORES.EXE
C:\WINDOWS\DESKTOP\NEW FOLDER\HIJACKTHIS.EXE
C:\PROGRAM FILES\SYMANTEC\LIVEUPDATE\NDETECT.EXE
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://plainfolkauctions.com/
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = localhost
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Local Page =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page =
N3 - Netscape 7: user_pref("browser.startup.homepage", "http://plainfolkauctions.com/"); (C:\WINDOWS\Application Data\Mozilla\Profiles\default\ed7djdgf.slt\prefs.js)
N3 - Netscape 7: user_pref("browser.search.defaultengine", "engine://C%3A%5CPROGRAM%20FILES%5CMOZILLA.ORG%5CMOZILLA%5Csearchplugins%5Cgoogle.src"); (C:\WINDOWS\Application Data\Mozilla\Profiles\default\ed7djdgf.slt\prefs.js)
O2 - BHO: (no name) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\PROGRAM FILES\ADOBE\ACROBAT 5.0\READER\ACTIVEX\ACROIEHELPER.OCX
O2 - BHO: (no name) - {724d43a9-0d85-11d4-9908-00400523e39a} - C:\Program Files\Siber Systems\AI RoboForm\RoboForm.dll
O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program Files\Norton AntiVirus\NavShExt.dll
O3 - Toolbar: &RoboForm - {724d43a0-0d85-11d4-9908-00400523e39a} - C:\Program Files\Siber Systems\AI RoboForm\RoboForm.dll
O3 - Toolbar: &Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINDOWS\SYSTEM\MSDXM.OCX
O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton AntiVirus\NavShExt.dll
O4 - HKLM\..\Run: [SystemTray] SysTray.Exe
O4 - HKLM\..\Run: [Dcfssvc] C:\Program Files\Common Files\KODAK\HYDRA_DR\dcfssvc.exe --pdr: "C:\Program Files\Common Files\KODAK\HYDRA_DR\dcmnter.pdr"
O4 - HKLM\..\Run: [PPMemCheck] C:\PROGRA~1\PESTPA~1\PPMemCheck.exe
O4 - HKLM\..\Run: [IntelliType] "C:\Program Files\Microsoft Hardware\Keyboard\type32.exe"
O4 - HKLM\..\Run: [LoadPowerProfile] Rundll32.exe powrprof.dll,LoadCurrentPwrScheme
O4 - HKLM\..\Run: [HPAIO_PrintFolderMgr] C:\WINDOWS\SYSTEM\hpoopm07.exe
O4 - HKLM\..\Run: [PestPatrol Control Center] C:\Program Files\PestPatrol\PPControl.exe
O4 - HKLM\..\Run: [TaskMonitor] C:\WINDOWS\taskmon.exe
O4 - HKLM\..\Run: [PCHealth] C:\WINDOWS\PCHealth\Support\PCHSchd.exe -s
O4 - HKLM\..\Run: [piiserviceOE] "C:\PROGRAM FILES\SPAM INSPECTOR OUTLOOK EXPRESS\SPAM INSPECTOR OUTLOOK EXPRESS EDITION\piiserviceOE.exe"
O4 - HKLM\..\Run: [CookiePatrol] C:\PROGRA~1\PESTPA~1\CookiePatrol.exe
O4 - HKLM\..\Run: [SysUpd] C:\WINDOWS\SYSUPD.EXE
O4 - HKLM\..\Run: [ScanRegistry] C:\WINDOWS\scanregw.exe /autorun
O4 - HKLM\..\Run: [OEMCleanup] C:\WINDOWS\OPTIONS\OEMRESET.EXE /O
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [ccRegVfy] "C:\Program Files\Common Files\Symantec Shared\ccRegVfy.exe"
O4 - HKLM\..\RunServices: [LoadPowerProfile] Rundll32.exe powrprof.dll,LoadCurrentPwrScheme
O4 - HKLM\..\RunServices: [*StateMgr] C:\WINDOWS\System\Restore\StateMgr.exe
O4 - HKLM\..\RunServices: [TrueVector] C:\WINDOWS\SYSTEM\ZONELABS\VSMON.EXE -service
O4 - HKLM\..\RunServices: [ScriptBlocking] "C:\Program Files\Common Files\Symantec Shared\Script Blocking\SBServ.exe" -reg
O4 - HKLM\..\RunServices: [StillImageMonitor] C:\WINDOWS\SYSTEM\STIMON.EXE
O4 - HKLM\..\RunServices: [SchedulingAgent] mstask.exe
O4 - HKLM\..\RunServices: [ccEvtMgr] "C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe"
O4 - Global Startup: ZoneAlarm Plus.lnk = C:\Program Files\Zone Labs\ZoneAlarm\zaplus.exe
O8 - Extra context menu item: &Check Spelling - res://C:\PROGRAM FILES\IESPELL\IESPELL.DLL/SPELLCHECK.HTM
O8 - Extra context menu item: &ieSpell Options - res://C:\PROGRAM FILES\IESPELL\IESPELL.DLL/SPELLOPTION.HTM
O8 - Extra context menu item: Add to White List - C:\PROGRAM FILES\ADVANCED SEARCHBAR\addtolist.js
O8 - Extra context menu item: Delete from White List - C:\PROGRAM FILES\ADVANCED SEARCHBAR\delfromlist.js
O8 - Extra context menu item: Fill Forms &] - file://C:\Program Files\Siber Systems\AI RoboForm\RoboFormComFillForms.html
O8 - Extra context menu item: Save Forms &[ - file://C:\Program Files\Siber Systems\AI RoboForm\RoboFormComSavePass.html
O8 - Extra context menu item: Customize Menu &4 - file://C:\Program Files\Siber Systems\AI RoboForm\RoboFormComCustomizeIEMenu.html
O8 - Extra context menu item: &Yahoo! Search - file:///C:\Program Files\Yahoo!\Common/ycsrch.htm
O8 - Extra context menu item: Yahoo! &Dictionary - file:///C:\Program Files\Yahoo!\Common/ycdict.htm
O8 - Extra context menu item: Yahoo! &Maps - file:///C:\Program Files\Yahoo!\Common/ycdict.htm
O9 - Extra button: AIM (HKLM)
O9 - Extra button: Trace (HKLM)
O9 - Extra 'Tools' menuitem: VisualRoute Trace (HKLM)
O9 - Extra button: ieSpell (HKLM)
O9 - Extra 'Tools' menuitem: ieSpell (HKLM)
O9 - Extra 'Tools' menuitem: ieSpell Options (HKLM)
O9 - Extra button: RoboForm (HKLM)
O9 - Extra 'Tools' menuitem: RF Toolbar   &2 (HKLM)
O9 - Extra button: Fill Forms (HKLM)
O9 - Extra 'Tools' menuitem: Fill Forms   &] (HKLM)
O9 - Extra button: Save (HKLM)
O9 - Extra 'Tools' menuitem: Save Forms   &[ (HKLM)
O9 - Extra button: Messenger (HKLM)
O9 - Extra 'Tools' menuitem: Yahoo! Messenger (HKLM)
O9 - Extra button: WeatherBug (HKCU)
O12 - Plugin for .mid: C:\PROGRA~1\INTERN~1\PLUGINS\npqtplugin2.dll
O12 - Plugin for .mp3: C:\PROGRA~1\INTERN~1\PLUGINS\npqtplugin3.dll
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
O16 - DPF: {DBB177CC-6908-4B53-9BEE-F1C697818D65} (QuickBooks Online Edition Utilities Class v4a) - https://accounting.quickbooks.com/v7.155/qboax4a.cab
O16 - DPF: {9F1C11AA-197B-4942-BA54-47A8489BB47F} (Update Class) - http://v4.windowsupdate.microsoft.com/CAB/x86/ansi/iuctl.CAB?37625.3053703704
O16 - DPF: {C2FCEF52-ACE9-11D3-BEBD-00105AA9B6AE} (Symantec RuFSI Registry Information Class) - http://security.symantec.com/SSC/SharedContent/common/bin/cabsa.cab
O16 - DPF: {2BC66F54-93A8-11D3-BEB6-00105AA9B6AE} (Symantec AntiVirus scanner) - http://security.symantec.com/SSC/SharedContent/vc/bin/AvSniff.cab
O16 - DPF: {A80D199B-CFDD-4DA4-8C47-2310D5B8DD97} (QuickBooks Online Edition Utilities Class v5) - https://accounting.quickbooks.com/v7.572/qboax5.cab
O16 - DPF: {0D3983A9-4E29-4F33-8313-DA22B29D3F87} (QuickBooks Online Edition Utilities Class v6) - https://accounting.quickbooks.com/v8.122/qboax6.cab
O16 - DPF: {DF6A0F17-0B1E-11D4-829D-00C04F6843FE} (Microsoft Office Tools on the Web Control) - http://officeupdate.microsoft.com/TemplateGallery/downloads/outc.cab
O16 - DPF: {F58E1CEF-A068-4C15-BA5E-587CAF3EE8C6} (MSN Chat Control 4.5) - http://sc.communities.msn.com/controls/chat/msnchat45.cab
O16 - DPF: {E87F6C8E-16C0-11D3-BEF7-009027438003} (Persits Software XUpload) - http://www.streamload.com/Upload/XUpload.ocx
O16 - DPF: First Class Solitaire by pogo.com - http://solitaire44.pogo.com/applet/solitaire2/solitaire2-ob-assets.cab
O16 - DPF: Keno by pogo.com - http://keno.pogo.com/applet/keno/keno-ob-assets.cab
O16 - DPF: Fortune Bingo by pogo - http://superbingo.pogo.com/applet-5.8.4.18/superbingo/superbingo-ob-assets.cab
O16 - DPF: World Class Solitaire by pogo - http://klondike.pogo.com/applet/worldclass/worldclass-ob-assets.cab
O16 - DPF: {E855A2D4-987E-4F3B-A51C-64D10A7E2479} (EPSImageControl Class) - http://tools.ebayimg.com/eps/activex/EPSControl_v1-0-3-0.cab
O16 - DPF: {2253F320-AB68-4A07-917D-4F12D8884A06} (ChainCast VMR Client Proxy) - http://www.streamaudio.com/download/ccpm_0237.cab
O16 - DPF: Keno by pogo - http://keno.pogo.com/applet-5.8.3.20/keno/keno-ob-assets.cab
O16 - DPF: {1D4DB7D2-6EC9-47A3-BD87-1E41684E07BB} - http://imgfarm.com/images/nocache/funwebproducts/ei/SmileyCentralInitialSetup1.0.0.8.cab
O16 - DPF: Spades by pogo - http://spades.pogo.com/applet-5.8.4.24/spades/spades-ob-assets.cab
O16 - DPF: {30528230-99F7-4BB4-88D8-FA1D4F56A2AB} (YInstStarter Class) - http://download.yahoo.com/dl/installs/yinst.cab
O16 - DPF: {B9191F79-5613-4C76-AA2A-398534BB8999} (YAddBook Class) - http://us.dl1.yimg.com/download.yahoo.com/dl/installs/suite/autocomplete.cab
O16 - DPF: {9DBAFCCF-592F-FFFF-FFFF-00608CEC297C} - http://download.weatherbug.com/minibug/tricklers/AWS/minibuginstaller.cab
O16 - DPF: {01CA75F1-054B-4A63-9221-C6926369EC52} (HS_live Control) - http://install.homestead.com/~site/InstallFiles/SIFiles/lpxlive/HS_live.cab
O16 - DPF: {166B1BCA-3F9C-11CF-8075-444553540000} (Shockwave ActiveX Control) - http://download.macromedia.com/pub/shockwave/cabs/director/sw.cab
O16 - DPF: {1954A4B1-9627-4CF2-A041-58AA2045CB35} (Brix6ie Control) - http://a19.g.akamai.net/7/19/7125/1410/ftp.coupons.com/v7/brix6ie.cab
O16 - DPF: {02BF25D5-8C17-4B23-BC80-D3488ABDDC6B} (QuickTime Object) - http://www.apple.com/qtactivex/qtplugin.cab
O16 - DPF: DigiChat Applet - http://216.40.212.51/DigiChat/DigiClasses/Client_IE.cab
O16 - DPF: {9A9307A0-7DA4-4DAF-B042-5009F29E09E1} (ActiveScan Installer Class) - http://www.pandasoftware.com/activescan/as5/asinst.cab
O16 - DPF: {15589FA1-C456-11CE-BF01-00AA0055595A} - http://www.errornuker.com/products/errn2004/installers/default/ErrorNukerInstaller.exe
TIA
Offline ketamininja
Re:I Was Hit!
« Reply #7 on: July 02, 2004, 13:56 »
Well, I'm no expert on the reg keys... mainly coz I can't be bothered going through them, but it looks like you have a few entries there. I'll wait for another techie to confirm.
Meanwhile, on the processes side, these look suspect:
Kill them, and try using adaware 6 again and Spybot Search & Destroy.
HTH
Offline Stormy
Re:I Was Hit!
« Reply #8 on: July 02, 2004, 23:33 »
I fixed it!  I won't have to reformat!
But aarrgghh!!! XUPITER!!!  That was the culprit!  >:(
That's the second time I got hit by them!  I figured I would give my system a really good look over before reformatting it.  And sure enough I found Xupiter in there reaking havoc!
That was a tough one!  Sheesh!  At lease I don't have to do the reformat now.  My scan disk and defrag also work.  Have a super weekend everyone, I'm a happy camper now!  ;D
