Author Topic: 1 Mb BB  (Read 5651 times)
Re:1 Mb BB
« Reply #15 on: July 07, 2004, 20:05 »
:eeek:
Re:1 Mb BB
« Reply #16 on: July 08, 2004, 00:01 »
Its a shame that you dont live in London Clive, you get get 1mb BB and TV for an introductory offer of £17-95 normally £35, or 2mb for £50  :o
http://www.homechoice.co.uk/hc_packages.html
Re:1 Mb BB
« Reply #17 on: July 08, 2004, 08:29 »
2Mb???  Steady on Sandra .....it will be a long time before BT rolls that out.
Re:1 Mb BB
« Reply #18 on: July 19, 2004, 23:46 »
I've been told subject to tests, I should be upgraded within 7 days.  Zoom zoom zoom....
12 days later....
I've just sent them an e-mail to remind them I still exist.  Good to know BT are still as efficient as ever.
Re:1 Mb BB
« Reply #19 on: July 20, 2004, 11:34 »
I've had a reply to say that today's the day.  Stand by for liftoff.  Yeah right!  :D
Re:1 Mb BB
« Reply #20 on: July 20, 2004, 16:42 »
I think I've got it!  According to
http://specials.zdnet.co.uk/misc/band-test/speedtest50.html
Your line speed:
1236.4 Kbps
151.5 K bytes/sec
That seems to be faster than they promised so no doubt they will cut that back when they find out.   ;D
Re:1 Mb BB
« Reply #21 on: July 20, 2004, 17:08 »
You're not going to gloat about this are you, Clive?   ::) ;) :P ;D ;D
Re:1 Mb BB
« Reply #22 on: July 20, 2004, 22:34 »
Moi?   ;D
Sadly, the euphoria didn't last long as the latest test shows an enormous drop in speed:
848.2 Kbps
104 K bytes/sec
Long live BT.
Re:1 Mb BB
« Reply #23 on: July 20, 2004, 23:20 »
Getting lower by the second!
Your line speed:
667.8 Kbps
81.8 K bytes/sec
Re:1 Mb BB
« Reply #24 on: July 20, 2004, 23:54 »
Re:1 Mb BB
« Reply #25 on: July 21, 2004, 00:03 »
Your line speed:
667.8 Kbps
81.8 K bytes/sec
Youve probably reached your monthly download limit now Clive so they capped it  ;D ;D ;D
Offline measter
Re:1 Mb BB
« Reply #26 on: July 21, 2004, 07:10 »
Your line speed:
1533.8 Kbps
188 K bytes/sec
1.5 mb beats 1 mb. ;D
Current CPU Info
Re:1 Mb BB
« Reply #27 on: July 21, 2004, 07:11 »
This morning is very different and the thermometer is off the chart.  This is what I call a connection!
Your line speed:
4080 Kbps
500 K bytes/sec
Offline Barra
Re:1 Mb BB
« Reply #28 on: August 04, 2004, 23:29 »
Bet you didn't get that the next time clive  :D
Have you tried tweaking it to try and get a bit more out of it?
Try here:-
http://www.dslreports.com/tweaks
Follow the prompts. Afterwards you will probably have to download DR.TCP, again follow prompts.
It's fairly straightforward. Must be, I managed it AND it WORKED
Re:1 Mb BB
« Reply #29 on: August 04, 2004, 23:41 »
It's 925 at the moment but varies quite a lot.  Thanks for the tweak Barra!  ;D
