Author Topic: PC Crash (slowdown) when using P2P (eg kiwi ares)  (Read 1196 times)
Offline redmars1983
« on: July 04, 2004, 03:50 »
:-\  this problem sux, the softwares seem to work fine for the first few minutes then crash, seems like something is stopping em from working. Also happens to BT downloads. Can someone help please?
Thanks in advance  ;)
Re:PC Crash (slowdown) when using P2P (eg kiwi ares)
« Reply #1 on: July 04, 2004, 09:19 »
It would help to have a few more details of your machine, i.e. which operating system are you using?  I have had this problem myself, and it turned out to be the firewall I had installed at the time, which didn't like WinMX for some reason.  I think it was Outpost.  I changed my firewall and it was fine after that.
Oh, and
Offline redmars1983
« Reply #2 on: July 05, 2004, 04:01 »
im running on WinXP SP1, P4 2.5ghz  512RAM and 160GB HDD
dont think they are the key tho.
I kinda think it's the firewall too, im using a demo version of Zone Alarm 5. Only gives the basic firewall tho.
I use Kiwi and Shareaza to download stuff. so....what firewall do u think i should have?
thanks
« Reply #3 on: July 05, 2004, 07:20 »
Try Sygate (link below).  I use that, and have never had any problems with P2Ps.   :)
Offline redmars1983
« Reply #4 on: July 05, 2004, 21:01 »
;D thanks a bunch for the help dudes! it's solved...now it's back to downloading for me :P  you guys rule!  8)
« Reply #5 on: July 05, 2004, 21:29 »
Glad it sorted.   :)
But Not yet sure what did you do to sort it.
Can you please tell us.    ::)
« Reply #6 on: July 05, 2004, 21:51 »
I'd kind of assumed he's changed his firewall, Joudi.   :-\
