November 28, 2024, 00:39
Technical Help & Discussion
Broadband, Networking, PC Security, Internet & ISPs
How do i get friendly 'ads back?
Topic: How do i get friendly 'ads back? (Read 801 times)
notaclue
New Member
July 08, 2004, 02:10 »
Hi
I 'stumbled' accross a site & now I have 'ladies' advertisment boxes at the top of every wannado homepage.
Need to make them disapear, back to normal 'ads.... hoping someone can help!
Thanks
joudi
Established Member
Re:How do i get friendly 'ads back?
July 08, 2004, 03:04 »
Hi Notaclue and welcome,
Probably the best to use as a first try is installing and running those two programs:
1 - "Spybot Search and destroy", Get it here:
http://www.softpedia.com/public/scripts/downloadhero/10-17-21
2 - "Ad-Aware", Get it here:
http://www.softpedia.com/public/scripts/downloadhero/10-17-58
Normally, a small download window must pop-up when you clic on it to download. If not, clic on one of the links on the page (Miror) to start downloading them.
If that doesn't solve your problem, come back here and tell us. There'll be a good girl in our forum will pop-Up to help you.
July 08, 2004, 07:50 »
Can't add to what Joudi said, but here's a couple of alternative download links, including Spyware Blaster, which, once your system is clean, will prevent future spyware / adware being installed without your knowledge.
Ad Aware
Spybot S&D
Spyware Blaster
notaclue
New Member
July 08, 2004, 10:47 »
Thankyou. I downloaded the first suggestion & then did a check & it found 24 'red' problems of which 2 were 'adult' related.
Thanks peeps, hopefully thats sorted my problem
