Author Topic: wdmaud.drv?!?!  (Read 888 times)
Offline jon996
wdmaud.drv?!?!
« on: July 10, 2004, 22:45 »
hi all ;)
i was doin a windows update and iv come a cropper!
its installing some update for my soundcard and its come up with "the file 'wdmaud.drv' on the Windows XP Professional CD-ROM is required"
but i cant find it on the cd so wtf shud i do?!?!?! ?
thankies
errmm ahhh sorted it :)
...jon :)
rive it like you stole it!
Re:wdmaud.drv?!?!
« Reply #1 on: July 15, 2004, 22:38 »
It's contained in a compressed form in one of the CAB files (Driver.cab I think).
One way to get it is to manually extract all the files from the CAB using the "expand" command
i.e. expand cab file name -fwdmaud.drv Destination
You will need to put the fully qualified name for the CAB location e.g. c:\windows\i386\driver.cab
