Author Topic: Cd / DvD Player Auto  (Read 2841 times)
« on: July 11, 2004, 20:06 »
Slight problem.. (niggle)
Last week on putting a CD/DvD into the player on my PC I used to get the option to click on if I wanted to show a DvD or play Music or Open folders to View, now I dont get any options at all unless I click windows key then "E".
I have gone into My Computer picked a Drive (CD/DVD player) properties and Auto player and changed it to select an action to perform and saved it..but it doesnt save, am I missing something blatently obvious here  ;D
Many thanks in advance  :)
Hookstar
Re:Cd / DvD Player Auto
« Reply #1 on: July 11, 2004, 20:07 »
That's happened to me too, so hopefully someone will have the answer.   8)
« Reply #2 on: July 11, 2004, 22:37 »
All Fixed  ;D
 :boogie:
« Reply #3 on: July 11, 2004, 22:39 »
That's helpful!  ::)  Are you going to tell me what you did?  ;)
« Reply #4 on: July 11, 2004, 22:42 »
Ah ah.. I think I know whats doing it, just had to put back Spywareblaster 3.2 and it went belly up again  >:( so it looks like for some reason its Spyware blaster?
« Reply #5 on: July 11, 2004, 23:42 »
Hmmm, I've got SWB 3.2, and mine has been like it for some time before I installed SWB.   :-\
« Reply #6 on: July 12, 2004, 12:20 »
Ok Simon, try this  ;) it worked for me just now  :D
http://tinyurl.com/stus
Hookstar
PS you might have to fix the link for me  :P
Edit:  Link modified by Clive
« Reply #7 on: July 12, 2004, 16:43 »
I think I know what I was doing wrong.  In My Computer > D: Drive > Propoerties > Autoplay, I had set it to ask what to do, but under Music Files.  I opened the drop down list, and found Music CD as well, so I selected that, told it to ask each time, and that's done it.  I ran that test anyway, Hook, and it all came up as OK.
Now I have another problem.  In the list if options, there is an option to Play in MusicMatch Jukebox, which I don't have anymore.  Is there any way to get rid of unrequired options from that list?
