Author Topic: Importing from Incredimail  (Read 700 times)
Offline Jo
« on: July 22, 2004, 23:42 »
Hi,
Have just installed Office 2003 and would like to start using Outlook instead of Incredimail.  It seems like it's not possible to import messages and contacts from Incredimail to Outlook...is this the case?  If so, do I just have to start from scratch and keep Incredimail installed in case I need to look at the messages?
Thanks, Jo
Re:Importing from Incredimail
« Reply #1 on: July 23, 2004, 08:36 »
Hi Jo, no I don't think it is possible to Import mail from Incredimail, because I tried myself some time ago.  They only way you could do it is to forward all the mail to yourself, sending with IM, but downloading using Outlook.  Bit messy, but it kind of works.
