Author Topic: loading cmos error  (Read 768 times)
Offline paradox2000uk
  • New Registration
loading cmos error
« on: July 27, 2004, 17:43 »
I have a problem with my bios settings i have recently just formatted my computer and started a fresh. Everything else is fine but when i turn my computer off for a while and turn it back on it does not activate the moniter but when i hit the reset button it activates the moniter but comes up with a warning saying that there was an error loading cmos and that defaults have been loaded but every time i turn it of at night it does the same in the morning could you help it would be really appriciated thanks Paradox
Re:loading cmos error
« Reply #1 on: July 27, 2004, 18:01 »
Hi Paradox and :welcome:
It sounds like you need to replace your mobo battery, as that holds the cmos settings when you shut the pc down  :)
