Author Topic: Difference? in Ata/UDMA/Ata  (Read 795 times)
« on: August 02, 2004, 18:17 »
Whats the difference in the 2 hard drives?
UDMA Hard drive and a Eide Hard drive.
Maxtor 6Y080L0 Plus 9 80gb 7200rpm UDMA133 hard drive
Western Digital Caviar 80Gb 7200rpm EIDE Hard drive
Just wondered thats all  ;D
And also AtA
Re:Difference? in Ata/UDMA/Ata
« Reply #1 on: August 02, 2004, 18:36 »
I think that this page will explain the UDMA and EIDE Hook :
http://openfacts.berlios.de/index-en.phtml?title=Ultra-DMA_HOWTO/What_is_Ultra-DMA_and_why_do_I_want_it%3F
Serial ATA is the new type of drive which most mobos older than around 24 months cant use and of the earlier ones that could use them they couldnt be used as a boot drive.
Newer mobos can use and boot from them.
They are faster speed in rpm and in data transfer and have a thinner more flexible cable with smaller connectors making them easier to connect if the drive is mounted awkwardly in the case and are easier to move out of teh way when fitting other parts in the pc  :)
« Reply #2 on: August 02, 2004, 18:52 »
Ty Sandra, its clear now, hopefully the one I ordered and recieved today will match up with my new Mobo  :-\
Supports AMD Athlon XP Athlon/Duron/Barton CPUs with frequency at 200/266/333/400 MHz in Socket A for Full Size ATX Form Factor.
Provides 2 DDR DIMM for DDR400/333/266/200 modules and memory size is expand up to 2GB.
Provides one 8X AGP slot one CNR slot Five 32-bit PCI slots; DirectSound CMI9739A Codec on board for Audio and Modem applications support 6 Channel speaker.
SiS963L provides 6 USB2.0 ports. (4 rear panel ports and 2 back panel ports)
10/100Mbps Fast Ethernet LAN on board supports IEEE 802.3 and 802.3u standards and fully compliant ANSI X3.263 TP-PMD physical sub-layer.
