Hi, 2 weeks ago I got a new pc built to my spec. It consists of ....
AMD Athlon xp300+ cpu, MSI K7N2 Motherboard, 512mb DDR 400 Ram and a serial ATA Maxtor 200gb HD, NVIDIA GeForce FX 5200 Ultra graphics card, LG DVD ROM and an NEC DVD RW running Win XP Pro SP1.
I have consistently been experiencing the same problem since day one, that is, the my pc will just power off completely. No warnings,no beeps,no blue screen, just shut off as if there has been a power cut. I have checked all the electrical connections and set it up in a different enviroment away from home and still the same shut off. It has been back to where i bought it from on 3 occasions now with the same fault only to return with the same fault.
I had it back for the 3rd time this weekend and was pleasantly surprised that it stayed on long enough this time for me to load various applications and all seemed to be well until i noticed that the cpu was showing as a 1.3 gigahertz AMD Athlon XP and of course an immense degrredation in performance.
First of all thought that the cpu had been changed and hence thats why it was sluggish. Well after a little research i found out that it was the cpu FSB clock that was responsible for this and that it had in fact been "Underclocked" to 100mhz and that was why it was still staying on. The place where i bought it assure me that the pc left there running at and rcognising an XP300+.
To cut a long story short when i increase the cpu bus to 166Ghz it is infact recognised as an XP300+ but i still get the same problem the machine just switches off. To have any use of the pc i have to "underclock" it to 133mhz and get the performance of 1.73ghz AMD if there is such a thing
Current cpu temp is 58c it gets to over 62c when running at 166mhz FSB and recognised as an XP300+ trouble is it then switches off but not always at that temp. Max i have seen it go to is 65c.
I have 2 extractor fans on a superflower case with of course the fan on the cpu. Bios is up to date, cpu warning temp is disabled and system temp is currently 40c.
Any ideas as to what the problem could be?
