Author Topic: constant alarm from the tower and speakers!!  (Read 836 times)
Offline cantona
  • New Registration
« on: August 06, 2004, 11:26 »
for some reason as soon as i start up i get an alarm from the tower that wont stop!HEEEEEEELP!!! :'(
Offline Camstop
Re:constant alarm from the tower and speakers!!
« Reply #1 on: August 06, 2004, 11:31 »
Hi cantona and  :welcome:
Can you please post your Pc spec and operating system and i'm sure a techie will be along soon to help  :thumb:
« Reply #2 on: August 06, 2004, 11:35 »
Hi Cantona and :welcome:
Is this as its booting up before the text appears on the screen ?
If so its usually caused by the memory or graphics card, one or the other may have gone faulty or maybe they have become dislodged slightly and just need reseating.
Or it could be the fan not running for the cpu.
I assume that you havent added any new bits between it being ok and this problem developing ?
Do you know which type of BIOS your pc is using or can you tell us which make and model of pc you have ?
Offline cantona
  • New Registration
« Reply #3 on: August 06, 2004, 11:37 »
intel celeron 1 ghz 384mb ram xp pro sp2
« Reply #4 on: August 06, 2004, 11:47 »
Any idea of the make and model of the motherboard so we can check which bios you have ?
Or if you dont know that and its an off the shelf pc, the make and model of the pc itself ?
