Author Topic: problem with pipex  (Read 2621 times)
problem with pipex
« on: August 07, 2004, 16:14 »
I can connect but am disconnected after 2 mins. When I try to reconnect I get message no dialtone.
I have uninstalled modem and re-installed and can connect but same disconnection after 2mins with same message.
I have upgraded the driver but with same results.
If I reboot I can connect again but only for a couple of minutes.
Any suggestions????????
Re:problem with pipex
« Reply #1 on: August 07, 2004, 17:49 »
It's news to me that it even looks for a dial tone, Lona, but that doesn't mean to say it doesn't.  If I were you, I might, however, just be inclined to check that I haven't inherited a rogue dialler from somewhere.  Check your Network Connections folder, to make sure it's just Pipex in there, then check IE Tools > Internet Options > Connections, to make sure it's dialling Pipex.  The only other thing I can think of to check is that your e-mail client isn't disconnecting after sending / receiving.
« Reply #2 on: August 07, 2004, 18:06 »
Did all that Simon. Checked out pipex site and it appears there has been a problem with connections. It is only affecting some but they are working on it.
It seems to be alright at the moment. :)
« Reply #3 on: August 07, 2004, 18:13 »
OK.  They usually fix things pretty quickly, Lona.  Mine is OK, so, as they said, the problem must be local.
« Reply #4 on: August 17, 2004, 19:11 »
Update on my connection problems.............
It has been getting steadily worse over the past week.  After reading No6's post about ZA I decided to uninstall it and re-install norton.  The problem was still there.
The error message is 645 and 680 when I try to re-connect.  If I go into outlook express and click work offline wait a few seconds I can reconnect.
I have tried uninstalling and re-installing modem and also checked all my connections configs.  Everything checks out OK and I have no conflicts in device manager.
I phoned Pipex today and after 30 minutes hanging on to speak to someone they said it could be Sky or my burgler alarm. Now I have had sky for years and no conflicts.  I phoned my alarm company and they said they get these complaints all the time from BT and that it can't be the alarm as it's not activated while I am online. To prove that it's not the alarm the engineer is coming tomorrow to disconnect the telephone dialler feature to eliminate that from the problem.
The interesting thing the alarm company asked was is it happening more often during the day and I said it was and he said that's when most businesses use the service.  In the evening it's not as often which makes me wonder if it is pipex after all and they are passing the buck.
I'm so confused now........
Is it Sky, is it the alarm, is it BT or is it Pipex.
I was up half the night last night trying to solve the problem but got nowhere.
« Reply #5 on: August 17, 2004, 22:10 »
Sorry Lona, I have no ideas.  Pipex is fine here, so all I can say is that your problem must be local, either your BT line, or something to do with your PC.  I don't quite buy the burglar alarm theory.  Just a thought, have you had a lot of rain recently?  Maybe some water has got into the BT line somehow?  I know this used to affect dial ups, but not sure if it can affect BB in the same way.
« Reply #6 on: August 17, 2004, 22:47 »
Well I did warn you Lona ::)......have you tried contacting Chirag Patel Tech Support Manager chirag@ndo.com   :whistle:  ;)
« Reply #7 on: August 18, 2004, 00:37 »
You could have a point there Simon but my phone works ok, so you would think I would be having telephone problems.
Tony, I'm pulling my hair out here so help would be nice rather than sarcasim. :P :-*
« Reply #8 on: August 18, 2004, 07:10 »
Had a quick Google, and Error 645 seems to be something to do with the encrypting of username / passwords settings (see here), and Error 680 means no dial tone.  As you can obviously connect some times, I think I might suspect either the BT line, or a faulty modem, Lona, but I'm only guessing.
« Reply #9 on: August 18, 2004, 10:05 »
Thanks Simon, had already read that url earlier. I've checked and double checked my connections and still can't find out the problem.  Perhaps when alarm engineer calls today he might have some answers.
Found this site last night.............
http://www.broadbandreports.com/faq/736
« Reply #10 on: August 18, 2004, 10:37 »
Here's something else I found about adsl filtering. I hope Cammy reads this post as he might be able to explain it in plain language.
http://www.clarity.it/telecoms/adsl_and_alarms.htm#1
« Reply #11 on: August 19, 2004, 00:24 »
sorry Lona I would love to help, but if I was having probs I'd get in touch with Tech Support, they get in touch with BT, and BT do a line check.
It's a process of elimination really, I assume it is a external ADSL modem, take it and your filters to a mates house and see if it connects their PC OK. You could even take your PC tower to their house, that way, you prove the filters the modem and your PC one way or the other. They all work then its you line, like I say a process of elimination. In an hour you could have tested all you kit, better than going around in circles for hours /days on end.   :-*
« Reply #12 on: August 19, 2004, 13:32 »
Tony, I assume the person whose house I was taking modem to would have to be BB connected.  None of my friends are on BB, in fact most of my friends are computer illiterates.;D
Pipex refused to contact BT until it was ruled out that it wasn't the alarm speech dialler that was cauing the problem.:(.
So the situation is that Pipex is blaming the alarm company, the alarm company is blaming BT and BT is blaming Pipex, which leaves me not knowing who's to blame.
I really have now come to the conclusion that it's usb related.
I have been cut off 3 times while trying to write this post.It really would try the patience of Joab.
 :tony:
« Reply #13 on: August 19, 2004, 15:11 »
Auto dialer on your alarm, I doubt it. I installed an auto dialer [infact I installed the whole alarm system] Infa Red, vibration and magnetic switching, the lot. For a kick off the auto dialer would only trigger if a alarm triggered. The one I fit was a auto dialer that auto rang up to five numbers with a recorded message, so I do not see the connection between that and your internet connection. I would think all remote monitored alarms would be set up to work on an analoge line connection. To be geared up otherwise would be commercial suicide, as ADSL is new not yet installed technology regards the vast majority on phone installations.
And all joking apart Lona, is times like these that going with a ISP that has first class support pays dividens.
Non of your neigbours got land line broadband Lona? you will have to start a Broadband club up your way.
« Reply #14 on: August 19, 2004, 16:23 »
Do you still have a dial up connection which you could try Lona?  At least that would eliminate a faulty phone line as the same line is used for both until it gets to the filter.
