Author Topic: Graphics connector on Mo/Bo  (Read 1342 times)
Offline Scotty_CFC
« on: August 08, 2004, 23:11 »
I bought a fan for my graphics card, the card has no fan pins so I need to plug straight into the motherboard. Where are the pins usually situated on the board?
Offline Scotty_CFC
Re:Graphics connector on Mo/Bo
« Reply #1 on: August 08, 2004, 23:18 »
This is my motherboard:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=gb&docname=bph07722&product=91012&dlc=en&lang=en
Offline bat69
« Reply #2 on: August 08, 2004, 23:19 »
Hi Scotty
The sockets for the fan connectors usually have three pins and are white in colour.  They can be located in various places depending upon where the manufacturer thinks about putting them (constraints of layout).
There will be one close to the CPU with another close by usually.  A third can usually be found near to the AGP port (the brown socket that the graphics card sits in)
If there are no spare sockets, then an adapter can be bought that connects into a power plug (the 4 pin plug that connects to Hard Drives, CD or DVDs etc) this will have an extra set of leads that terminate in a fan plug
Hope this helps
Offline bat69
« Reply #3 on: August 08, 2004, 23:23 »
Thanks for the pic Scotty
It doesn't seem to have a spare fan power socket.
I suggest you get a lead with a fan supply on it to connect to the power supply leads.
I'll locate one so you know what you are looking for. Just a mo
Offline bat69
« Reply #4 on: August 08, 2004, 23:27 »
Try Here
It is the fourteenth one down ... "Adapter which allows you to connect 3pin Motherboard-style Fan Power Plugs onto a standard 4 pin PSU Connector."
Offline Scotty_CFC
« Reply #5 on: August 08, 2004, 23:30 »
Great!  :D Cheers for the help, gonna have to dig deep for that 90p  ;) Thanks
Offline bat69
« Reply #6 on: August 08, 2004, 23:32 »
Great,  I hope you get it sorted
I'm sure with a little searching you will find one cheaper than 90p ;) ;)
Offline Scotty_CFC
« Reply #7 on: August 08, 2004, 23:32 »
BTW, the fan plug has only 2 pins, will it still work with the 3 pin connector?
Offline bat69
« Reply #8 on: August 09, 2004, 00:00 »
Yes the third wire, usually a yellow one, is a sensor wire for the fan to allow it to be monitored by the mobo
