Author Topic: Linux  (Read 2187 times)
Offline Hiatus
    • JoshSalverda.com
Linux
« on: August 11, 2004, 04:40 »
I dunno if this is the rite place for asking this, but I think it could be considered "upgrading" your PC...
Anyways, I've been thinking about changing to Linux/Unix as my main OS. Anybody have any experience with Linux?
If you do, can you suggest any good "kinds" (OS's?)?  ???
I've heard that Linux isn't very compatible with a lot of Windows software...does this count for everything? Is it worth changing over or should I just keep Windows...?
l33t h@x0r... sort of...
Re:Linux
« Reply #1 on: August 11, 2004, 08:53 »
I think that there are a number of Linux people using the forum Hiatus and I'm sure they will help out if you get stuck.
Re:Linux
« Reply #2 on: August 11, 2004, 13:02 »
I think that most people who run Linux dual boot with a MS OS as well or just have a second pc just for Linux.
I think this is software rather than upgrading so I will move it there  :)
Offline WhiteDevil
Re:Linux
« Reply #3 on: August 11, 2004, 18:02 »
Hi,
If you want to try an "easy" linux distribution from the many out there i recommend Mandrake Linux http://www.mandrake-linux.com, i have managed to dual boot this with Windows XP as Sandra said - Do you have 2 hard drives? I found it better to run 2 hard drives with a different OS on each...
dam Boyle
Owner, Director
www.Severn-Computers.com
Offline Hiatus
    • JoshSalverda.com
Re:Linux
« Reply #4 on: August 12, 2004, 01:07 »
I don't have two hard drives...yet, at least. When I get my new computer I'll probably get two 40 gig hd's.
So, you can dual boot? How would I go about doing that...?
Edit:
How much space would I need for Linux? I have an extra 4 gig (I think) hd around.
Re:Linux
« Reply #5 on: August 12, 2004, 01:29 »
Just as an experiment as Linux is a small OS you could probably use youre 4 gig drive for it.
You could even partition your existing drive, if its big enough and use that new partition for Linux but I think its beter having a seperate drive.
Dual booting with windows OSs is usually done with the older OS installed first and the newer one installed afterwards.
I am not sure of the best way for Linux but most people seem to install it when they already have a windows OS on initially.
I would be tempted to add your 4 gig drive as a slave to your current drive and install Linux to that drive and see how it goes  :)
Offline Hiatus
    • JoshSalverda.com
Re:Linux
« Reply #6 on: August 12, 2004, 22:14 »
Hmmmmm, either the link(s) aren't working or my DSL connection sux... :-\
I can't d/l linux rite now, maybe I can eventually order it or check out a local comp store.
Re:Linux
« Reply #7 on: August 12, 2004, 23:57 »
The links to the download page works ok for me but some of the sites on that page are down.
This one appears to be fine at the moment :
ftp://ftp.phys.ttu.edu/pub/mandrakelinux/official/iso/ppc/
Maybe it doesnt like ME though  :P
Offline Hiatus
    • JoshSalverda.com
Re:Linux
« Reply #8 on: August 13, 2004, 15:05 »
Yea...too bad im on XP tho,  :lol:
Re:Linux
« Reply #9 on: August 13, 2004, 15:21 »
Sorry Hiatus, I thought that it was you sticking up for that crappy ME OS  :o
Was same avatar  :)
Offline Hiatus
    • JoshSalverda.com
Re:Linux
« Reply #10 on: August 13, 2004, 18:22 »
lol, yes, that was me. I use two different computers (well, three if u include my laptop). One is our family comp (Win XP) and the others are both Windows ME.
From what I've seen, Windows ME is the best OS so far. 8)
XP is close, but it is still second in my opinion.
Offline Michelle
    • Techieminx
Re:Linux
« Reply #11 on: August 13, 2004, 19:31 »
I've no idea what this thread is about but I couldn't help noticing this!!
ME rules okay lol
No I still haven't got xp on this thing!  ::) ;D
Still works tho!
Re:Linux
« Reply #12 on: August 13, 2004, 20:07 »
Welcome back, Michelle!   8)
Offline Michelle
    • Techieminx
Re:Linux
« Reply #13 on: August 13, 2004, 20:12 »
Thanks Si did ya miss me  :P
Offline WhiteDevil
Re:Linux
« Reply #14 on: August 14, 2004, 20:32 »
If you havent had any luck downloading Mandrake yet i recommend using SmartFTP and not Windows Explorer, its just quicker  ;D
To dual boot, its best to install Windows XP first because you have NO choice to configured its bootloader... When you've done that one, stick in the Mandrake CD1 (or CD2, some drives dont recognise CD for 1 some reason)...
When you get to the configuration stage take a look here: http://www.geocities.com/desktopmandrake/linuxwithxp.htm.. If all goes well you'll be able to dual boot (i recommend the Grub bootloader, ive never had any luck dualbooting with LILO)...
Good luck  ;D
dam Boyle
Owner, Director
