Author Topic: Started to Build new PC  (Read 10354 times)
« on: August 13, 2004, 16:08 »
Ok.. I have all the parts now to start building the new PC, watch this space  :)
Spec so far on the parts I have
·   Pc chips Mobo 848 lu
·   AMD XP 2500 Barton
·   Maxtor 80gb 7200 rpm
·   XP Home
·   Saphire ATI Radeon 128 MB 9200se GPH Card
·   2 x 256 mb DDR400 PC3200 Crucial Memory
·   Pioneer 16x DVD RW
·   Aopen 16 x DVD Rom
·   Liteon 40x 12 x 48 CDRW
·   ATX I Chia  Aluminium Case
·   Winfast TV / PVR
Ps.. It will take about a week to finish building.
PPS.. I know its a crappy Mobo but I was originaly building a pc for my Daughter but changed my mind, she can have my old one now  ;D
Re:Started to Build new PC
« Reply #1 on: August 13, 2004, 18:43 »
Some of the Bits  8)
« Reply #2 on: August 13, 2004, 19:28 »
Just curious Hooky  :)
Why have you gone for 2 x 256mb and not 1 x 512mb, future expansion is likely to mean replacing one of them with a 512mb if you decide to increase the memory later as most mobos seem to be coming with only 2 slots these days  ???
Why are you bothering with a cd writer when you have a dvd writer  ???
« Reply #3 on: August 13, 2004, 20:33 »
Sandra, I have had some advice from the PC Chips friends that if you put 1 in slot 1 and 1 in slot 3 to activate dual Channel. And my logic reckons if 1 goes wrong you still have one left  ;)
Also The cd writer fills up the other compartment  ;D
« Reply #4 on: August 13, 2004, 20:39 »
So, what are you going to put in the forth slot?  ;D
« Reply #5 on: August 13, 2004, 20:44 »
Nexus Fan control and temp Monitor with 3 usb and 1 firewire port  ;)
« Reply #6 on: August 13, 2004, 20:47 »
Ahh...  8)
« Reply #8 on: August 13, 2004, 21:53 »
Yeah, I was looking at one of those myself last year, but never got round to getting one.  I think I came to the conclusion that I didn't really need it, not that that usually stops me buying stuff!   ;D
Offline Hiatus
    • JoshSalverda.com
« Reply #9 on: August 14, 2004, 02:16 »
OMG, I love it! :o
That's almost the same comp I want! (Specs-wise).
Only thing I would change so far is the graphics card. Radeon X800 all the way! 8)
P.S. What's the equivalent of the AMD XP 2500 Barton for a Pentium Processor? P4 2.5Ghz? Apparently AMD is better?
l33t h@x0r... sort of...
« Reply #10 on: August 14, 2004, 08:35 »
Hiatus, As I'm not a gamer (games are banned on this puter and any puter I own  ::) ) this Graphics card is all I need  ;) and is ample for my needs.
And yes the 2500 AMD Barton is of excelent value @ £47
« Reply #11 on: August 14, 2004, 11:11 »
Ive changed my Mind  :o on the MOBO, thought if I have a half decent PC why bugger it up with a crappy MOBO, anybody got any idea's on a decent MOBO.. answer before 6 Sunday night  8) please
« Reply #12 on: August 14, 2004, 12:25 »
The 2500 Barton runs at 1833mhz so technically the Intel P4 is the same speed although they work slightly differently so some people would say the the AMD is faster but some say the Intel is as fast and is more reliable.
Take your pick  :)
« Reply #13 on: August 16, 2004, 20:36 »
I agree with your comments Hooky My Boy, now a decent MOBO, well all things considered I would have to suggest a....Oh bugger it's Monday .........  ::)
« Reply #14 on: August 16, 2004, 21:01 »
Thanks Tone  :P
Have ordered an Asus A7v8X-X Mobo from Novatech, hopefuly will be here on Wednesday  ;D
