Author Topic: New build or Upgrade? worth a look  (Read 1369 times)
« on: August 17, 2004, 16:59 »
Thinking of a building a New PC or upgrading you existing one
XP3200 Barton proccessor, heat sink and fan, and ASROCK K7S8X-E [a bloody good Mobo]@ £127 its got to be worth a look
HERE
Offline Barra
Re:New build or Upgrade? worth a look
« Reply #1 on: August 18, 2004, 18:59 »
Went to chk out the spec then remembered, I haven't got a clue what I'm looking at. But it sounds good :D
« Reply #2 on: August 19, 2004, 00:05 »
Well Ade, that lot from Dabs would cost you £171 delivered. You could say, you are getting the MOBO and the Heatsink/Fan for free, as the CPU alone would cost you £129 delivered.......young man  ;D
Indeed I'm suprised Simon is not pestering some freind or relation to have a new PC built  ;D
Offline Barra
« Reply #3 on: August 19, 2004, 08:41 »
young man  ;D
Ah, you say the sweetest things ;) ;D
Simon has a friend ??? ;) :P
