April 14, 2025, 21:57
Technical Help & Discussion
problem installing software
Topic: problem installing software (Read 1186 times)
blackpool_uk
New Member
August 18, 2004, 13:08 »
when trying to install winrunner on my W2K machine i'm recieving an error message upon clicking setup.exe
"c:\winnt\system32\autoexec.nt the system file is not suitable for running MS-DOS and Microsoft Windowns applications. choose close to terminiate the application."
any ideas??
thanks in advance
Matt
Sandra
Ultimate Member
Re:problem installing software
August 18, 2004, 13:40 »
Hi Matt, have you installed and been able to run this version under 2K before ?
Which version is it as I have come across this :
Version 6.02 is needed for Windows 2000
DJ
Established Member
August 18, 2004, 14:40 »
Though I am not sure of how to solve your problem Matt, I just wanted you to know that I have had winrunner running on a Windows 2000 PC. The version was 6.02
Basically winrunner is a test tool or automation tool. It has been used to do a batch update of thousands of accounts on the system we use at work.
DJ
blackpool_uk
New Member
August 18, 2004, 15:50 »
hi,
it's version 7.5 and a colleague has installed it fine on his PC running w2k.
it's a wierd message, never come across it before, tried the usual basic things such as copying the data onto the harddrive first but no joy.
any ideas???
Sandra
Ultimate Member
August 18, 2004, 17:35 »
Have a look at this Matt :
This issue can occur if any of the following Windows 2000 or Windows Server 2003 files is missing, damaged, or not located in the %SystemRoot%\System32 folder:
Autoexec.nt
Command.com
Config.nt
Info and possible remedy here :
http://support.microsoft.com/default.aspx?scid=kb;EN-US;305521
blackpool_uk
New Member
August 19, 2004, 11:40 »
thanks sandra that solved it.
cheers
matt
Sandra
Ultimate Member
August 19, 2004, 12:13 »
Pleased to hear its sorted
