Author Topic: Tricks of the Trade  (Read 791 times)
Tricks of the Trade
« on: August 24, 2004, 20:26 »
Love this site!  Shame there isn't more of it!
http://www.themorningnews.org/archives/how_to/tricks_of_the_trade.php
Re:Tricks of the Trade
« Reply #1 on: August 24, 2004, 21:00 »
I like this one, at work we use a ball of blue tack.
Mechanic
If you have to change a light bulb where the glass is broken, you can press a potato into the metal base to unscrew the remains of the bulb from the fixture.
Blondes huh  ;D
Technical Support
When helping someone fix their computer over the phone, and you want them to see if all the cables are plugged in correctly, don?t ask, ?Have you checked to see if the cable is plugged in?? because the customer will always say, ?Of course I did, do you think I?m a moron?? Instead say, ?Remove the cable, blow the dust out of the connector, and plug it back in.? The customer will most likely reply, ?Hey, it?s working now?I guess that dust really builds up in there!?
 ;D  ;D  ;D  ;D
