Author Topic: SDRAM  (Read 855 times)
Offline Barra
SDRAM
« on: August 29, 2004, 19:57 »
After using AIDA32 (thanks Hook, another new toy to play with) it showing my 512 SDRAM as only 411mb. Isthis normal or...............?
Re:SDRAM
« Reply #1 on: August 29, 2004, 20:08 »
Usually a difference between the actual installed amount of ram and that indicated is caused by the onboard graphics using it.
Normally I would expect a difference of 16, 32, 64 or possibly 128mbs.
101 is an unusual figure though and I thought that you had an AGP card  ???
Offline Barra
Re:SDRAM
« Reply #2 on: August 29, 2004, 20:35 »
I have got an AGP card :(
Re:SDRAM
« Reply #3 on: August 29, 2004, 20:39 »
No6 I to have found a new toy called PC Wizard .. have posted the url in another section  ;)
