Author Topic: PC information  (Read 928 times)
PC information
« on: September 01, 2004, 11:27 »
Oh !!!  Got to the train late..   :(
Isn?t there a trick to let me get up on time?    ;)
Well, there?s a French proverb which says: ?vaux mieux tard que jamais?. Which means: ?Better to be late than never?.    :)
OK !!!  Let?s go?
If you like to get information about your computer and its? components, without the need to install ?Aida? or ?SiSoft Sandra?, here?s a way:
Go to the menu ?Start?, then the ?Help Center?, to the heading ?choose a Title?, then take the forth one ?Use Tools to display the information about your PC and diagnostic problems?.
That will take you to a new page entitled ?Tools?.
Go to the tab on the left-side and choose one of those two:
?Advanced system information?
?Information about my computer?
There you are.    :)
(If the technical expressions or words which I?ve used are not exactly so in English, maybe one of the administrators or moderators can modify them. Thanks)
