Author Topic: Knackered Hard Drive  (Read 1332 times)
Offline DJ
« on: September 01, 2004, 23:16 »
Hi All,
I have a IBM 80gig hard that has given up the ghost.
I can't access it through windows or dos and it makes a very loud clicky noise.  This is a slave (secondary) drive so i can still access windows but have lost a lot of data (I know I should have backed it  up!).
Anyway, can anyone recommend recovery software? I have looked at iRecover but would rather find a cheaper alternative...
Any Suggestions? :-\
DJ
Re:Knackered Hard Drive
« Reply #1 on: September 01, 2004, 23:26 »
You could try Easy Recovery Pro DJ but if the drive isnt spinning up I dont think anything will work without using a specialised dat recovery service  :(
Offline DJ
« Reply #2 on: September 01, 2004, 23:31 »
Is that from www.ontrack.co.uk ?? I'll have a proper look in the morning.
I download the trial of irecover and it is working - not sure if the disk is spinning or not now?  iRecover will just take ages as it only lets you recover parts of the data at one time (unless I upgrade to the full version).
I suppose iRecover isn't that bad - think its bewtween $50 - $100.
DJ
« Reply #3 on: September 01, 2004, 23:34 »
I think I would try easy recovery pro DJ, I have never used it myself but have heard that its very good  :)
Offline DJ
« Reply #4 on: September 01, 2004, 23:44 »
Thanks Sandra  ;) :-*
Will have a proper look at it in the morning..
Off to catch some :snooze:
Thanks again
DJ
Offline DJ
« Reply #5 on: September 02, 2004, 13:23 »
Easy recover pro is up and running and working like a dream, recovering my lost data.
Thanks Sandra for your efficient and helpful replies (as usual)  :-*
DJ
« Reply #6 on: September 02, 2004, 15:59 »
Best of luck, DJ.  It's a horrible feeling when you think you might have lost everything.
