Author Topic: Connection Speed  (Read 1473 times)
Offline Hiatus
    • JoshSalverda.com
Connection Speed
« on: September 04, 2004, 04:23 »
I have DSL and I was wondering about this speed thing...
How come in my internet status window it says that it's speed is 100mbps, but if I go to one of those sites that tests your internet connection speed it says it's 130kbps?
l33t h@x0r... sort of...
Re:Connection Speed
« Reply #1 on: September 04, 2004, 10:41 »
The 100mbps refers to the network speed on your LAN, the 130kbps is your connection speed to your WAN (or ISP).
Was someone using a second PC while you ran that test as its a low connection speed unless your not on 512 ADSL  ???
Offline Hiatus
    • JoshSalverda.com
Re:Connection Speed
« Reply #2 on: September 04, 2004, 15:16 »
The other computer we have isn't connected to the internet...so I don't think there are other computers using the connection.
How would I be able to find out if we have a "512 ADSL" or not?
Re:Connection Speed
« Reply #3 on: September 04, 2004, 15:33 »
Who are you with and how much per month do you pay  ???
Re:Connection Speed
« Reply #4 on: September 04, 2004, 21:20 »
Try the speed test on ADSL Guide (link below) which will tell you your DSL speed pretty accurately.
Re:Connection Speed
« Reply #5 on: September 04, 2004, 23:20 »
I think someone had had a drink before posting the previous post  ;)
Heres the link :
http://www.adslguide.com/index.php?page=5&action=url&link_cat=17&sid=a9be07506f6b5145e4bd515a446a058f
Re:Connection Speed
« Reply #6 on: September 05, 2004, 09:06 »
Me :drunk: never!
Actually Sandra, what I meant was that the link to ADSLGuide can be found below i.e in the "Recommended Sites" links at the bottom of this page ::) :P
Offline Hiatus
    • JoshSalverda.com
Re:Connection Speed
« Reply #7 on: September 10, 2004, 21:27 »
Sorry...I didn't see this reply earlier. The computer I used to use was with Sympatico (I think....) and I'm not sure about the price.
Guess that's not much help, but meh. I'm on a diff connection now (at college) with my 1.8mbps! Oh yea! :lol:
Re:Connection Speed
« Reply #8 on: September 12, 2004, 11:32 »
Just tried the speed test..
464.2 kilobits per second
Communications 464.2 kilobits per second
Storage 56.7 kilobytes per second
1MB file download 18.1 seconds
Subjective rating Not bad
How does that compare with others with a typical 512k
