Author Topic: Faster navigation with "Internet Explorer"  (Read 2788 times)
« on: September 05, 2004, 02:31 »
You can gain some seconds while waiting the Internet page to open, when there are animated images on the page..
Go to ?Option Internet? in the ?Control Panel?, and take the option ?Advance?. Then, in the section ?Multimedia? you can untick: ?Play the animations?. Still you need to click ?OK?.
The result will be showing only the first image of the animation.
Re:Faster navigation with "Internet Explorer"
« Reply #1 on: September 05, 2004, 02:48 »
You would miss out on all the sigs on Pals if you did that  :o
« Reply #2 on: September 05, 2004, 08:46 »
Thank you Youdi..you a gem  ;D have been looking for ways to do  that for ages  ;)
« Reply #3 on: September 05, 2004, 09:34 »
Ironic you've found that, just as you're about to get Broadband, Hook!   :P ;) ;D ;D
« Reply #4 on: September 05, 2004, 10:57 »
Jumping at the chance to miss out on all the sigs, I followed Joudi's instructions with glee.  Sadly, it makes no difference.   :'(
« Reply #5 on: September 05, 2004, 11:51 »
 :bart:
« Reply #6 on: September 05, 2004, 11:53 »
You might be right Clive. I didn't try it myself yet. I have to leave soon now. Well, I revised that point on the other site, and found that they're talking about "Internet Explorer 5".
Well, thought, logically, it must work for "Explorer 6" too. We need the confirmation from others about that then.   :)
« Reply #7 on: September 05, 2004, 15:30 »
I use IE6, Joudi, and it didn't work for me. :(
« Reply #8 on: September 05, 2004, 19:47 »
It didn't work for me neither.
In fact, although I unticked that option of animated images, the images continued to play.
Well, in that case we need the help of a techie to tell us about the function of that option when it's ticked or not.
« Reply #9 on: September 05, 2004, 20:15 »
Shall we have a new section?  "Tips, Tricks and Tweaks that don't work!"   ;D ;D
Sorry Joudi, couldn't resist.   ;) :lol:
« Reply #10 on: September 05, 2004, 20:53 »
:)  Ok Simon, but that's an option which is there in internet explorer for something. Why when I tick it or untick it it doesn't make any difference? It must have a function. What is its' function?
That's my wondering for.   :-\
« Reply #11 on: September 05, 2004, 21:55 »
Sorry to make a joke of it, Joudi.  ;)
I wonder if it's because the sigs on here are Flash animations?  Maybe you have to uninstall Flash Player, in order to be free of the sigs?   :-\
« Reply #12 on: September 05, 2004, 23:15 »
I think that you will find that if its unticked it wont play animated gifs, they will only show the first frame and appear as static ones Joudi.
As Simon says, the sigs are flash animations so fortunately it wont stop those  :)
« Reply #13 on: September 06, 2004, 00:17 »
Then, have you tried that method on a site with animations like that Sandra? Does it work as Tip?
« Reply #14 on: September 06, 2004, 00:44 »
Sorry Joudi , I havent had time to try but ZA has a similar setting that stops animated gifs but not flash ones  :)
