Author Topic: Serial ATA HD Problem  (Read 2185 times)
Offline kevinho
« on: September 07, 2004, 08:42 »
Im running windows xp pro with a 200gb maxtor diamond max 10 serial ata hard drive.
Over the weekend i encountered the BSOD with the error message Kernel Stack Inpage Error with lots of numbers after it  :)
On reebooting xp couldnt find a HD and no bios installed and was searcing for ide drives etc and would not load.
I did a little googling and concluded that my problem was related to the drives power supply cabling. So i disconnected the power cable to the drive reconnected it and it booted no probems for a while then the same thing happened again BSOD (Same message) etc .
So yesterday i changed the power cable to the HD and it worked again, I left it on over night and it crashed  :( but no BSOD this time just a failure to find HD on bootup.
Removing and replacing the power connector to the HD enables it to boot up again but unfortunately i think its just a matter of time before i will get the same problems again.
Anybody have any ideas?
Re:Serial ATA HD Problem
« Reply #1 on: September 07, 2004, 14:46 »
Hi Kevin, can you have a look here :
http://support.microsoft.com/?kbid=315266
And check which code your lots of numbers refer to  :)
Offline kevinho
« Reply #2 on: September 07, 2004, 15:16 »
Hi Sandra, I have checked that page and didnt find the info relevant as on the both occasions i encountered the BSOD, the "Lots of numbers" were different on both occasions and there do not appear to be any bad sectors on the drive although i am unable to check with maxblast or power max utility and there is nothing in the system log that indicates an error!
I will check the numbers that it threw at me again just to make sure i have not missed anything. I have checked the RAM and it appears ok but perhaps i had better leave the ram test run for longer.
What does work is disconnecting the HD power cable and reconnecting it and then all is fine but it appears to be unstable and i cant figure out why or how ???
« Reply #3 on: September 07, 2004, 15:22 »
How long has it been running prior to this problem and which mobo have you got ?
« Reply #4 on: September 07, 2004, 15:24 »
Duff PSU at a Guess  :-\
Offline kevinho
« Reply #5 on: September 07, 2004, 15:38 »
Its been running for about 2 months now I have an MSI k7n2 Delta mobo the psu was changed to a 400w about 2 months ago as well
« Reply #6 on: September 07, 2004, 15:44 »
New components are at their most vulnerable when new..thats the prime time for them to break up IMHO.
Offline kevinho
« Reply #7 on: September 07, 2004, 15:55 »
Ah well i bought the whole system from new new about 2 months ago its allready had a new cpu, a new psu and a new graphics card in that time. I am loathe to take it back again just to be told that its working fine here and then get it back for it to break down again. Is there any way i can test the psu for a fault?
« Reply #8 on: September 07, 2004, 16:17 »
I found this on the MSI site :
Question
K7N2 (MS-6570) failed to boot after loading high performance default
Solution
Please do the following:
1. clear CMOS
2. load high performance default
3. go to advanced chipset setup (dont need to change anything)
4. press ESC
5. Save & exit
Nvidia has added some modules on the BIOS for memory performance & stability. However, the modules need to load both high performance default & go to advanced chipset setup as mentioned in order for the modules to finished initializing
It may be worth a try  :)
Offline kevinho
« Reply #9 on: September 07, 2004, 16:22 »
Thanks Sandra I will try that tonight. Any ideas how i can test my psu for a fault?
« Reply #10 on: September 07, 2004, 16:28 »
Not really Kevin, usually its by substitution unless you know someone whos into electronics and could test it underload  :(
Offline kevinho
« Reply #11 on: September 11, 2004, 07:59 »
Well things have moved on and i cant now boot the pc  :(
I am getting the following...
No Array is defined ....
Press cntrl + f to enter fast build utility or escape to continue boot
then it goes to
Nvidia boot agent PXE-E61 - media test failure check cable
then
Disk boot failure insert system disk and press enter
Any ideas
« Reply #12 on: September 11, 2004, 12:20 »
Its sounding like a mobo fault, as its not recognising the boot drive by the sound of it :(
Offline kevinho
« Reply #13 on: September 11, 2004, 12:35 »
Well I've just been out to buy a new PSU  see how that goes first. Just hope i will be able to make sense of all these cables :)
Offline kevinho
« Reply #14 on: September 11, 2004, 15:12 »
Well I changed the psu and no difference still exactly the same  :(
It will have to go back again  :brick:
This computer has spent more time being repaired than it has with me  :curse:
Anyway thanks for your help.
