Author Topic: win 2k bsod  (Read 808 times)
Offline jman
  • New Registration
win 2k bsod
« on: September 08, 2004, 20:04 »
Hi everyone,
I just installed a 56k modem on my pc. I am running win 2k prof. Now, when I try to connect to the internet this blue screen pops up that says STOP: a bunch of numbers and then physical memory dumping. I then have to restart my computer. Can anyone help?
Offline Camstop
Re:win 2k bsod
« Reply #1 on: September 08, 2004, 20:44 »
Hi jman and  :welcome:
I'm not a techie but...
Sounds like it may be a problem with the modem drivers and you would be best to get the latest ones from the manufacturers web site...
Also can you check in: Control Panel/System/Hardware/Device Manager... and see if you have any yellow question marks or red X'es...
And can you tell us what make and model your modem is  :thumb:
That should keep you busy until a real techie turns up  ;)
Re:win 2k bsod
« Reply #2 on: September 08, 2004, 20:48 »
Hi jman and
Is this a replacement modem, or the first time you've connected the PC to the Internet?
Re:win 2k bsod
« Reply #3 on: September 08, 2004, 21:37 »
jman sent me a PM (by mistake?), saying that the PC was given to him, but it didn't come with a modem, so he's put one in.
Jman, do you have a Firewall and Anti Virus protection installed?  If not, you may be getting the Blaster worm, or something similar, when you connect to the Internet.
