Author Topic: E mail probs  (Read 1944 times)
E mail probs
« on: September 10, 2004, 18:55 »
Hi folks  ;D only me  8)
Today finaly got BB, everything seems fine apart from not being able to get my Hotmail account to work, this account is not my main mail? as I use this one for signing in to junk sites etc??
I have checked all the settings, it worked before I upgraded to BB........just cant see anything wrong ..oh by the way its the same for Mrs Hook and the young hookstars.
Cheers for any info.
Re:E mail probs
« Reply #1 on: September 10, 2004, 20:32 »
The only mail setting you should need to change for existing mail accounts, is the SMTP server, for outgoing mail.  Do you download your Hotmail mail with Outlook / OE, Hook, or do you use Hotmail.com?  I suppose it might be possible that your new ISP won't allow you to download Hotmail through it's servers, but I would have thought unlikely.   :-\
Re:E mail probs
« Reply #2 on: September 11, 2004, 08:17 »
Simon, this is the error report I keep getting?
Unable to poll for new messages on your HTTP server.  Account: 'Hotmail', Server: 'http://services.msn.com/svcs/hotmail/httpmail.asp', Protocol: HTTPMail, Port: 0, Secure(SSL): No, Socket Error: 12019, Error Number: 0x80004005
have tried Googling but .. ???
Re:E mail probs
« Reply #3 on: September 11, 2004, 09:19 »
Try this, Hook >>
CAUSE:- Your local area network (LAN) or Internet service provider (ISP) proxy server or firewall does not recognize Web Distributed Authoring and Versioning (WebDAV) extensions. This prevents Hypertext Transfer Protocol (HTTP) e-mail messages from working correctly.
Re:E mail probs
« Reply #4 on: September 11, 2004, 09:35 »
I think that only works for OE5 Simon  :-\ mine is OE6
Re:E mail probs
« Reply #5 on: September 11, 2004, 09:56 »
Hmm... never noticed that.  ::)  Have you tried deleting the Hotmail account in OE, and setting it up again?  Other than that, I think you'll have to wait for someome more technical to come along.  It does say in that article, that it could be something to do with your ISP.
Re:E mail probs
« Reply #6 on: September 11, 2004, 10:01 »
This isn't some sort of firewall problem?
Re:E mail probs
« Reply #7 on: September 11, 2004, 10:10 »
It was ok before I went on BB..could it be my Router?
Re:E mail probs
« Reply #8 on: September 11, 2004, 10:23 »
Assuming the router has a firewall, but not knowing how router firewalls work, I'm guessing, but can you remove the Hotmail entry from the firewall Applications List, like in a software firewall?  Then would it ask for permission next time?  Hotmail is a different protocol to POP3, as you'll know, so may need separate permission through your router firewall.  As I said, I'm only guessing.
Re:E mail probs
« Reply #9 on: September 11, 2004, 10:47 »
The router will definitley have a firewall so I think that needs adjusting.  Not quite sure how you go about it though.
Re:E mail probs
« Reply #10 on: September 11, 2004, 12:09 »
I should think that Hotmail probably uses different ports to Pop3 accounts (they use 110 and 25 for pop3 and smtp).
Unfortunately I dont know which ports Hotmail mail uses but if you can find which it uses then just open them in your router and it should work fine  :)
Re:E mail probs
« Reply #11 on: September 11, 2004, 12:17 »
How would I find that out Sandra ?? been googling the best part of 90 mins looking for a solution  :-\
Re:E mail probs
« Reply #12 on: September 11, 2004, 12:24 »
I looked too before I posted Hooky, without any success so far  :(
I will have another look later to see if I can find it for you  :)
Re:E mail probs
« Reply #13 on: September 11, 2004, 12:35 »
Ok cheers Sandra  :D
Re:E mail probs
« Reply #14 on: September 12, 2004, 17:23 »
Well what do you know?? Hotmail is all up and running again now  :-\......I dont know sometimes computers baffle me  ???
