Author Topic: Firewall or not ??  (Read 1399 times)
Firewall or not ??
« on: September 12, 2004, 19:36 »
Do I need Sygate firewall now I have a Router ?? plus SP2 Firewall is also activated??
 8)
Re:Firewall or not ??
« Reply #1 on: September 12, 2004, 21:21 »
I found that with my router firewall, Zone Alarm became more of a nuisance than anything else as it prevented me from accessing any Yahoo site.  I now just use the router and XP firewall.  Is the SP2 firewall different to the standard XP?
« Reply #2 on: September 12, 2004, 21:26 »
As far as I know Clive, SP2 firewall is a lot stronger than the normal XP.. hopefully one of the techies will back up what I'm saying  ;)
Offline Hiatus
    • JoshSalverda.com
« Reply #3 on: September 12, 2004, 21:31 »
The Windows Firewall is much better than its Internet Connection Firewall (ICF) predecessor, but still no match for a 3rd-party personal firewall solution such as ZoneAlarm
First of all, the Windows Firewall does not monitor or block outbound traffic.
According to the PCWorld article Overton pointed out that if malicious code gets past the firewall it is the role of antivirus software to handle it.
The Windows Firewall also relies on API's which can be disabled.
Quote(s) from: http://netsecurity.about.com/od/firewalls/a/aa081804b.htm
Interesting article, good information.  :)
l33t h@x0r... sort of...
« Reply #4 on: September 12, 2004, 22:39 »
Having a firewall is a bit of a belt and braces approach when you have a router with a NAT Hooky.
I still have nortons firewall on but its never shown any attempt of anything to get in during the last 18 months or more that I have had my router.
It wont do any harm to have a firewall on but probably not do any good either  :)
« Reply #5 on: September 12, 2004, 23:22 »
I have took Clive's advice and took off my firewall (Sygate) and I think everything is running that bit faster  ::) Mind games  8)
« Reply #6 on: September 13, 2004, 07:06 »
Did you get the Netgear router in the end Hook?
If so, you have a brilliant stateful packet inspection firewall built-in and, if it is configured properly, you will not need a software firewall.
Time to RTFM I think :)
« Reply #7 on: September 13, 2004, 07:16 »
Yes got the Netgear modem/router and apart from the ISP giving me a wrong Address was very easy to set up.
On line wizzard was most helpful  :)
Thanks for giving me more confidence on not having a software firewall  ;)
RTFM???
« Reply #8 on: September 13, 2004, 12:16 »
Sorry Hooky I know that its against mens religion but I think Adept is saying "Read The F******* Manual"  ;D ;D ;D
« Reply #9 on: September 13, 2004, 13:16 »
NFM with the router  :P as he will find out when he orders his
Just an Instalation guide  ;)
