Author Topic: Closing many windows at the same time  (Read 802 times)
« on: September 17, 2004, 00:10 »
If you have many windows open on your desktop, and you like to close them all together at the same time, you just hold the ?Ctrl? key pressed while left-clicking on those windows in the ?Taskbar? to highlight them, the one after the other. After that, you just need to right-click on anyone of that selected group and take the option ?Close?.
Re:Closing many windows at the same time
« Reply #1 on: September 17, 2004, 07:13 »
Or switch to Avant, which will do that by clicking on the x at the top right hand corner.  Best of all is that it will automatically reload them all again for you next time you connect to the Internet.  ;D
« Reply #2 on: September 17, 2004, 19:37 »
A good one to know is pressing SHIFT and closing a computer window (with the X) will close all the associated windows of that application.
