Author Topic: Dragging and dropping objects between full screen applicatio  (Read 825 times)
It's very easy to drag and drop objects between programs as long as the target program is not covered by another program. Here's a way to drop objects on programs that are hiding behind other programs:
1.   Drag the object over to your target program's icon in the task bar, but don't drop it quite yet.
2.   Wait a few seconds until Windows automatically opens the target program (which used to be hidden) for you, and drop the object as usual.
