Author Topic: Transfering Outlook Msg/addy  (Read 1081 times)
« on: September 24, 2004, 16:19 »
Ok quick Question  ;D
Outlook express 6
I am now running the new comp? how do I transfer all my Msgs plus Adresses to the new pc???.
Many thanks
Re:Transfering Outlook Msg/addy
« Reply #1 on: September 24, 2004, 17:14 »
Donno Hooky My Boy....but its dead easy with Mozilla Mail backup ;D  ;)
« Reply #2 on: September 24, 2004, 17:35 »
I was only saying to Clive last night how quiet it was in here  :P
« Reply #3 on: September 24, 2004, 17:42 »
Try using the Files and Settings Transfer Wizard Hooky  :)
This wizard helps you transfer files and settings from your old computer to your new one. You can transfer settings for Microsoft Internet Explorer and Microsoft Outlook Express, as well as desktop and display settings, dial-up connections, and other types of settings. As you go through the wizard, you can select the files and settings that you want to transfer.
Use Files and Settings Transfer Wizard To Transfer Files
Get the files and settings from the old computer:
Click Start, click Accessories, click System Tools, and then click Files and Settings Transfer Wizard.
Click Next, click Old Computer, and then click Next.
Select a transfer method, such as Floppy Drive or Other (such as a removable or network drive), and then click Next.
Select the appropriate option for the items that you want to transfer:
Settings only
Files only
Both files and settings
Customize
Click Next, click OK, and then click Finish.
On the New Computer:
Click Next, and then click New Computer.
Click to select the I don't need a Windows XP CD-ROM. I have already collected my files and settings from my old computer check box.
Select Floppy drive or Other, depending on how you stored your files.
Select Yes or No to log off of the computer. The new settings do not take effect until you log off.
Click Finish.NOTE: The transfer method under Direct Cable only supports serial ports and cable, and not parallel ports and cable.
« Reply #4 on: September 24, 2004, 18:05 »
Thank you Sanrda  ;)
« Reply #5 on: September 24, 2004, 20:27 »
« Reply #6 on: September 24, 2004, 20:32 »
I saw that one Simon.. but wanted an easier option with 4 other accounts to do as well  ;D
