Author Topic: Adobe  (Read 3812 times)
Adobe
« on: January 16, 2003, 18:06 »
Anyone know the difference between Adobe Photoshop 7.0, and Adobe Photoshop Elements?  I've got Elements, but was wondering if this had more or less facilities than APS7?
Re:Adobe
« Reply #1 on: January 16, 2003, 18:27 »
PC-Pro magazine reviewed Photoshop Elements 2 recently. You may find the review useful Simon.
Re:Adobe
« Reply #2 on: January 16, 2003, 18:52 »
 That could be handy, Adept!
Re:Adobe
« Reply #3 on: January 16, 2003, 23:03 »
I take it you have version 1 Simon, cough,cough  ;)
Re:Adobe
« Reply #4 on: January 16, 2003, 23:18 »
Could I ask what is the difference between Photoshop and Paintshop?. Are they just different packages that do the same thing?
Re:Adobe
« Reply #5 on: January 16, 2003, 23:47 »
Version 2, Tony!    ;) >:D >:D
Basically, yes, Lona, but personally, I now prefer Photoshop, as it seems easier.  I've only just started playing with it though, so I'll probably find things Photoshop can't do that PSP can, and vice versa.
Re:Adobe
« Reply #6 on: January 16, 2003, 23:58 »
sw**ker  ;) :)
Offline DualBoy
    • http://www.pingme.ca
Re:Adobe
« Reply #7 on: January 17, 2003, 03:36 »
I have used Photoshop all the way back to version 4.0 about 7 years ago now I think. Been a very long time. Moved to 5 then to 5.5 and 6 and 7. I dont use 7 much but have a copy of 5.5 installed at work and 6.0 here at home. I personally say version 5.5 to be the best version released by Adobe so far. 7.0 is not my cup of tea from some changes. But 6.0 Seems quite decent so far. Only been using it 6 or so months though.
Re:Adobe
« Reply #8 on: January 17, 2003, 21:16 »
Somebody offered to send me a help manual for paintshop on this forum. Was it you Dualboy? If so I didn't receive it. :-";"xx
Re:Adobe
« Reply #9 on: January 17, 2003, 21:25 »
No it was Greenking Lona.He was having problems scanning it in but managed it eventually and sent it to me.I will forward it to you as he was wanting to check it was ok before mailing it on again I think  :-*
Re:Adobe
« Reply #10 on: January 17, 2003, 22:09 »
Poor Greenking. He seems to be having a lot of problems lately. I hope you are not as GREEN as you are cabbage looking greenking
Offline greenking
Re:Adobe
« Reply #11 on: January 18, 2003, 19:24 »
I've been having problems since birth Lona.
I mistakenly thought I'd get a computer to escape from my problems ;D ;D ;D
"idiotproof" they told me,  they weren't banking on my interlect  :-[ :-[ :-[:yoops:
Re:Adobe
« Reply #12 on: January 18, 2003, 21:48 »
Don't worry about it Greenking. You are among some of the biggest idiots here ;)I got your files from Sandra. Much appreciated if I ever get around to having time to edit my pictures :welldone:
